09-19-2010, 18:59 | #1 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1057695 Status: Offline Thanks Meter: 29 | strange 1209 contact service the phone give me contact service i clean it very good 1- i erase flash with jaf and install v4.11 and new pm 2-unlock the phone and factory setting it open with jaf and with sim give me sim not vaild with battery give contact service i remove the the charge soket and try the phone chang lcd and lcd flex when open with battery give contact service and with jaf give sim not vaild |
09-19-2010, 22:18 | #2 (permalink) |
Registered User Join Date: Aug 2009
Member: 1087294 Status: Offline Thanks Meter: 252 | bro check imei if not ok write rpl and unlock with mxkey and for contact service short two resister near lcd jack |
The Following 2 Users Say Thank You to bruightmobile For This Useful Post: |
09-20-2010, 07:21 | #3 (permalink) | |
Member: 1057695 Status: Offline Thanks Meter: 29 | Quote:
whem erase flash Backup IMEI zone... Setting local mode... Reading IMEI... Reading IMEI data... IMEI data corrupt... Getting MCUID... MCU ID: 0x2292 Reading flash chip detailes... FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 MCU ID: 0x2292 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! this is info Switching to serial... Powering the phone... Reading... MCU SW version: V 4.11 10-11-07 RH-105 (c) NMP HW version: 1600 PCI version: UEM version: 1328 UPP version: 8850 RFIC version: 0700 DSP version: P06w45.v41 LCD version: SDI:NAXv89 S6B33BD PPM version: V 4.11 10-11-07 RH-105 (c) NMP IC ADSP SW version: V 4.11\n10-11-07\nRH-105\n(c) NMP\nic Production serial number: DBM578929 Product code: 0550577 Module code: 0203484 Basic production code: 0515534 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 358236036809653 IMEI spare to net: 3A 85 32 06 63 08 69 05 IMEI SV to net: 33 85 32 06 63 08 69 45 F3 Master Code: 0536747407 Failed reading simlock data... Phone type: RH-105, Software version: 4.11, Language Pack: IC User code: ÿ# Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-105.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0550577 Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ Searching for default location of ini... Checking path: \Products\RH-105\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! i want to know sim not vaild indicat what imie is ok | |
The Following User Says Thank You to x_man_2002 For This Useful Post: |
09-20-2010, 07:33 | #4 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: siliguri,india Age: 31
Member: 1183572 Status: Offline Thanks Meter: 203 | Quote:
and solution is one new rpl ,request for new rpl in forum than write thisl than unlock ur phone ur problem will be solve. | |
The Following 2 Users Say Thank You to adityajha For This Useful Post: |
09-20-2010, 07:36 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: \/\/ 0RLD \/\/ IDE
Member: 238374 Status: Offline Sonork: 100.1597005 Thanks Meter: 1,087 | Use Jaf 1.98.62 version then unlock and post result Br, .::Dr.Gsm::. |
The Following User Says Thank You to .::Dr.Gsm::. For This Useful Post: |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Strange unlocking | Dens666 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-14-2000 14:45 |
FREE SP unlock service | timxy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-22-1999 16:05 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
