06-26-2006, 13:50 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: INTERNET
Member: 128981 Status: Offline Thanks Meter: 6 | Strange 3410 ??? I have one Nokia 3410 power on and light on and Viber on, when i connect battery. how to fix this problem, plz? many thanks |
06-26-2006, 14:32 | #2 (permalink) |
No Life Poster Join Date: Aug 2002 Location: india Age: 63
Member: 14578 Status: Offline Thanks Meter: 831 | check 20 pin ui ic on pcb right side of sim connection. resoldre it if no result. reples it. wbr Last edited by baraka42; 06-26-2006 at 14:37. Reason: add attechment |
06-27-2006, 04:34 | #3 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: tamil nadu Age: 38
Member: 170244 Status: Offline Thanks Meter: 418 | Quote:
yes the solution is 1000% o.k try this. | |
06-27-2006, 11:10 | #4 (permalink) | |
Member: 128981 Status: Offline Thanks Meter: 6 | Quote:
thanks | |
06-27-2006, 12:16 | #6 (permalink) | |
what's wrong? thanks | |
06-28-2006, 07:36 | #10 (permalink) | |
Member: 14578 Status: Offline Thanks Meter: 831 | check the cobba ? Quote:
pls. when you have no idea about tested solution. search first then reply here. this is just ui releted fault. wbr | |
06-28-2006, 08:28 | #11 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Pinoy in KSA
Member: 236698 Status: Offline Thanks Meter: 38 | i almost forgot this issue coz of the age of the model but may be i have something to share to you guys, you're right bakara42 it's UI "related" problem, i would suggest to try another N400 ic, if the phone still the same or much worse than before the problem is not only from N400! dont 4get CPU drives the N400, pin C12 & G12 are responsible to it, just observe the other hot pins around, when this 2 pins shorts w/ the other pins it will trigger the N400 automatically! so my concern is, to look for the short circuit either in or outside the CPU, specially for water dammage phones! galo |
strange 3410 charge problem | thecult | Nokia Hardware & Hardware Repair | 17 | 12-31-2004 10:09 |
Strange 3410 | gyuszko | Nokia Multimedia | 3 | 10-16-2003 14:53 |
Strange 3410 | blah | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-10-2003 19:20 |
strange 3410 - please help | questman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-27-2003 02:53 |
Strange 3410 !!! | Rossifan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-23-2003 22:36 |
