05-19-2008, 18:23 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Kenya
Member: 70343 Status: Offline Thanks Meter: 38 | A strange 6280 I have a strange 6280. It came to me dead. I have flashed the phone with both Jaf and HWK. Both tools flash sucessfully, but the phone does not power on. When I change to "normal mode" in Jaf, The screen turns light grey, and the keypad lights up. When I run self tests with Jaf, it passes all except lcd test. Funny thing is, when I take the lcd and test it with another handset, it works well. I would appreciate some advice from hardware gurus on this forum. Thanks! |
05-19-2008, 21:56 | #2 (permalink) |
Freak Poster Join Date: May 2006
Member: 278058 Status: Offline Thanks Meter: 81 | You know that the power switch is connected to the mainboard by the flex cable! If the phone goes into normal mode via flash cable, then you should change the flex. Do you hear a sound when connecting charger btw? |
05-19-2008, 22:06 | #3 (permalink) |
Freak Poster Join Date: Jan 2008 Location: In Front Of Screen Age: 40
Member: 674037 Status: Offline Sonork: 100.1577050 Thanks Meter: 13 | You shold to have the last version of the softwere then run The main setup file Then Go to Jaf flasher Be sure Is the phone on the local mode then Tick The option manual Flash and Press the Button use Ini the Select Your mobile Phone If The Files select automaticaly press fast phone option then flash your problem will be solve 100% I had been try these solation br |
05-20-2008, 10:49 | #4 (permalink) | |
Member: 70343 Status: Offline Thanks Meter: 38 | Quote:
Yes, I can hear a sound when I connect charger. The phone does not show anything on the screen. It only changes colour from black to a light grey. | |
05-22-2008, 19:50 | #6 (permalink) | |
Member: 278058 Status: Offline Thanks Meter: 81 | Quote:
Strange 6280 LCD problem | thinkbot | Nokia Hardware & Hardware Repair | 15 | 04-09-2008 12:41 |
Strange 6280 Contact Service | Phantom | UID - Box | 5 | 09-20-2007 12:34 |
strange 6280 flashing problem | abdulhaf | HWK | 12 | 09-22-2006 08:55 |
