06-12-2006, 22:20 | #1 (permalink) |
Junior Member Join Date: Jan 2005
Member: 110818 Status: Offline Thanks Meter: 1 | Strange 6680 Problem... 3G Signal? |
06-14-2006, 20:58 | #2 (permalink) |
Member: 110818 Status: Offline Thanks Meter: 1 | Sorry to seem impatient, but surely somebody in this community must have an idea what's up and how to fix it? There seems to be a lot of collective knowledge here on Nokia phones, but I haven't seen any problems like mine. I see I can get a new antenna on ebay, but I don't really think that's the problem...? Edit: I just upgraded to 5.04.07 using the method described on this site, and the first time I tried to make a call under 3G it said 'Connection Error', where previously it would just have dropped out before connecting a call, but that might just be a feature of the new firmware version. Oddly, I managed to make a perfectly clear call severl minutes long after that, too, so now I'm even more mystified. Edit: I'd guess the problem is with Tx, not Rx, since it seems to hold a signal fine until I try to do anything that involves communicating with the network, or am I assuming too much here? Last edited by Azurael; 06-14-2006 at 21:30. |
06-21-2006, 05:52 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Age: 67
Member: 58052 Status: Offline Thanks Meter: 21 | 3g Hi mate there does not seem 2 b many profs on the later nokia since u may notice many posts are answered very poorly even some mods cannot supply any support, just take a look at how many posts there regarding signal on 6630-6680-n70 they r not even been answered, CNT problems ape boot problems and u can go on and on lately every second guy is having problems flashing these phones and no support is coming forth so dont expect much help, But yes concering your problem i have noticed on the 6680 once u switch to 3g mode signal is at certain times gone but on normal gsm there is no problem, i discussed this with many guys here working with nokia and according to them 3 g signal is different to gsm signal and that is where the problem is, so i suppose we will have to wait and see what will come of this; Regards Len |
08-02-2006, 03:40 | #5 (permalink) |
Insane Poster Join Date: Dec 2004 Location: Adelaide Australia Age: 39
Member: 96184 Status: Offline Thanks Meter: 6 | the rf section of the phone is built around two RF ASICs, Rx ASIC N7500 and Tx ASIC N7501. there are also two PAs on the board, one for GSM (N7502) and one for WCDMA (N7503). the WCDMA PA needs variable supply voltage to work power efficiently and therefore there is a switched mode power supply (SMPS) component (N7504) added to the PWB. it sounds like the RSSI signal may be too high- if you know how to test it, if not then the component responsible for this is the crystal 32mhz if i can rememer correctly. this causes calls to drop if it is faulty. to teast it you need to be using phoenix and the test software phone test. you would also need tuning equipment. transmitter functions are implemented in the RF ASIC named VINKU. VINKU contains three seperate RF paths- GSM900, GSM1800/1900 and WCDMA. the CMT flash stores the tuning values. if this is faulty and needs to be replaced then you need to restore the security certificates which very fee can do. what i mean is these components may be at fault, and you need to test the phone using phoenix and phone test to determin what is causing the fault. BB5 reception faults are very difficult to identify and would take for ever explaining it in a reply. personally i would start with the crystal- its easy to replace and is likly to cause the fault. following one of the PAs and diplexer. i can give you much more detail or in a giant nut shell if you email me. |
08-02-2006, 04:22 | #6 (permalink) |
nokia 6680 strange sim problem | petermov | Nokia Hardware & Hardware Repair | 4 | 03-25-2009 05:37 |
6680 Strange Charging Problem | torpedo_seluler | Nokia Hardware & Hardware Repair | 2 | 08-16-2008 10:15 |
Nokia N70 3G signal problem | bruama80 | Nokia Base Band 5 ( BB-5 ) | 1 | 12-16-2006 07:33 |
Ive got a strange network problem whit 3120,signal is perfect on 1800 Mhz,but on 900 | Tilka | Nokia Hardware & Hardware Repair | 3 | 10-26-2006 10:24 |
Ive got a strange network problem whit 3120,signal is perfect on 1800 Mhz,but on 900 | Tilka | Nokia Hardware & Hardware Repair | 5 | 07-27-2006 12:42 |
