Old 03-17-2006, 17:04   #1 (permalink)
Member: 164628
Thanks Meter: 2
strange problem in 6600
Hi mates,
I have a nk6600 which was showing' cbus error" when flashing with ufs.I HAVE changed bt-module but problem is same after that i flashed it with bt-flashing disabled.Now it flashed completely but phone starts with white screen&after that off.
wbr
Old 03-17-2006, 17:11   #2 (permalink)
Member: 117126
Try to use a different PM file
Hello Mental
ur problem may be solved by Pm files.
Just check that ur handset is taking the UI options or no. If UI options are ok, then write a good Pm file and ur handset might be free from the problem u r facing.
I had the same problem earlier and solved the same by a good Pm .
Just try and chek..
Bye
Deepak
JSK
Old 03-17-2006, 21:14   #3 (permalink)
Crazy Poster
Member: 220962
Thanks Meter: 2
Maybe UPP cause, u reball it and flash again. Good luck!
strange problem in 6600 vbfather Nokia Hardware & Hardware Repair 3 04-25-2006 15:09
strange problem in 6600 ...... MR PROTEC Smart-Clip 1 12-27-2005 17:26
strange problem in 6600 parthiv_sk Nokia Multimedia 11 10-31-2005 12:20
a strange problem in 6600 lcd magnom Nokia Hardware & Hardware Repair 6 10-07-2004 09:28
Page generated in 0.15860 seconds with 9 queries
