08-15-2009, 09:16 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: DAMMAM Age: 43
Member: 262523 Status: Offline Sonork: 100.1611482 Thanks Meter: 288 | System hardware work on Nokia BB5 EM is TAHVO including ASIC function block: CORE-supply generation (VCORE & VCOREA) Level-shifter and regulator for USB / FBUS Battery-control processes such as the charging External LED-driver control interface -Digital interface (CBUS) -TAHVO ASIC does not have any security function of the withdrawal UEM (E, K) CMT Flash CMT Flash memory used to store: -MCU program code DSP-prgram code -Tuning Values -Certificates Capacity-64Mbit Logic-supply voltage and for NOR Flash in the output from the VIO (1.8V) Flash Clock is 48Mhz (192Mhz / 4) CMT SDRAM CMT SDRAM is dinamic data storage for the MCU data Capacity 64MBit SDRAM core voltage (1.8v) output by the regulator RETU VDRAM Voltage I / O (1.8) in the output by RETU VIO regulator SDRAM clock is 96Mhz (192Mhz / 2) OMAP OMAP is an application of the system running with Symbian (EPOC) Platform for ease of use application, the basic interface (Main Interface): -Cameras The screen - -Bluetooth MMC - -USB -Keyboard XBUS-to medium with RAP3G OMAP is a standard ASIC design by Texas Instrument and in use by the Vendor and other NOTEBOOK VCORE CORE Voltage (1.4V generated by the discrete SMPS and work under 1.09V on sleepmode I / O voltage VIO (1.8V) by RETU APE COMBO MEMORY APE flash used to store application code and user data Lets not to access the code directly from Flash ---> loader must walk to and from DDR 256MBit capacity (flash), 256MBit (DDR) DDR voltage to 1.8V is VDRAM VIO is 1.8V of DDR I / O Both NAND core voltage and I / O originating from RETU Clock is 110Mhz DDR (220MHz / 2) Flash interface speed is 22MHZ |
The Following 2 Users Say Thank You to faisal4friend For This Useful Post: |
Guide | Update Firmware On Nokia BB5 Devices via Phoenix Service Software 2009 | Shayesta197 | Nokia Base Band 5 ( BB-5 ) | 0 | 10-03-2009 01:43 |
Update Firmware On Nokia BB5 Devices via Phoenix Service Software 2009 | Shayesta197 | Nokia Base Band 5 ( BB-5 ) | 0 | 09-13-2009 21:36 |
System hardware work on Nokia BB5 | faisal4friend | Nokia Hardware & Hardware Repair | 2 | 08-15-2009 09:19 |
just working on nokia on others no network or loose network | falak | TORNADO - SIM | 6 | 04-28-2008 07:46 |
How to reset lifetimer on Nokia BB5 | Mocko | Nokia Base Band 5 ( BB-5 ) | 8 | 01-06-2007 19:51 |
