10-10-2003, 18:00 | #1 (permalink) |
No Life Poster Join Date: Sep 2002
Member: 15837 Status: Offline Thanks Meter: 2 | Test Jig Problem I have tested both the 3310 and 8210 one but I have a problem Using Wintesla 7.05 everything is fine unil you do the self tests, when it starts it says everything is passed but when you try and run the tests again it gives an error anyone else got this problem ? also what program are everyone using with there test jigs ? |
10-11-2003, 11:18 | #3 (permalink) |
Member: 15837 Status: Offline Thanks Meter: 2 | What program and version are you useing and can you rerun tests ok. For example : I connect an 8210 jig then run wintesla 7.05 (also tried 6.03) and choose NSM3. After a few seconds i get a display with SW numbers and warranty info etc.. i then choose Testing/self tests from the drop down menus. All tests show either passed or not executed. I then select a test (cobba serial for example) and run it. The program resports "setting test mode" then says "running". After about 30 secs a warning box appears saying "failed to run self test". Do you use the PKD1 dongle? |
For SALE: Original Nokia Service Equipment - TEST JIGS / TEST BOXES / PKD-1NS / FPS-4 | nokiaking | Sell ur Old and Used Stuff | 4 | 01-04-2004 11:10 |
test jig ...!!! | MrHazeem | Wanted Products | 1 | 11-08-2002 07:03 |
nokia board test jig | farry | Main Sales Section | 4 | 08-11-2002 00:46 |
2 6210 test jigs required | G-Man | Main Sales Section | 0 | 06-18-2002 23:54 |
