Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 03-25-2010, 13:46   #1 (permalink)
Dooha_Bd's Avatar
Member: 1427033
Sonork: 100.1596688
Angry TRICKS OF CNT failed 1200,1208.1650 etc
"extracting content pack failed"
LINK-------------4shared.com - online file sharing and storage - download trik CNT failed pada 1200,1208.1650 etc.rar
The Following 2 Users Say Thank You to Dooha_Bd For This Useful Post:
Old 03-25-2010, 20:36   #2 (permalink)
Hariom123's Avatar
Member: 804452
trick extracting content pack failed to 1200.1209 & 1650:
as we know if CNT (content packs) does not enter the flashing process
phone will be dead a total or contact the service.
maybe with a little trick the phone will be able to help friends without having to play hardware.
This trick is my test on several phones with the same case and the results are successful,
but on condition that we must have MXKEY UFS + HWK.
- Do flashing process as usual using MXKEY
- When the process failed extrcting cnt flashing process will stop and come with an option tab ok / cancel
- Do not select cancel, remove the flash cable from the phone and battery tempelin pin (pin flash do not stick)
- Press the power on to appear "test mode" on the phone screen
- Click 'ok' on the options tab
- Extracting CNT to enter
if already full erase can still way above, but at the write PM's easier to use UFS + HWK
how:
- After flashing with MXKEY (way above)
- Select a check on the HWK suite
- Then click info ... if the info does not appear use tricks "test mode" as above
- If new info has emerged write PM ....( if it failed repeat of info click yes)
- If successful PM must go ....
now living repair simlock
for better ways to use it because it's easier MXKEY
- Can check on the bus pake MXKEY may also not
- If you're sure the phone is connected then go through the simlock info
- Simlock info will not immediately come out, so pake again "trick test mode"
- If the info appears dah new simlock select update simlock
- Wait to go .... time patching patching process selasai buru2 and pull the cable gunain "trick test mode"
- That'll be in repair simlock on hp test mode condition
- If successful will open all simlock
good luck
nb: it's rather difficult trick of having to pull the plug wire to flash ... so ya do not give up
full detail by dooha_Bd ---------try than post result
Hariom
Old 03-25-2010, 20:46   #3 (permalink)
Member: 756129
can use this link that works:
Blue-Nokia.com by Obnoxy
Old 03-30-2010, 01:02   #4 (permalink)
Member: 1260148
Sonork: uyut
thanks for solution that is great for me
The Following User Says Thank You to btscell_2010 For This Useful Post:
Need Latest Setp Of Hwk For 1200 1208 1650 ameho0102 Nokia Hardware & Hardware-Repair Area 9 07-14-2008 22:29
1200-1208-1650???? asrar HWK 3 02-04-2008 08:39
1200/1208/1650 IMEI PATCHER+UNLOCKER, Check this out!! yobb Main Sales Section 0 02-02-2008 11:51
Page generated in 0.31931 seconds with 11 queries
