07-04-2011, 21:27 | #1 (permalink) |
Freak Poster Join Date: Oct 2010 Location: !!!Suck Me I Know You Can!!!
Member: 1421351 Status: Offline Sonork: 100.1605689 Thanks Meter: 143 | .::TroubleShoting And how to SOLVING::. so we can have knew,how to solved a problem without jumper trick or solution picture, cause many CASE have different solution SO: -we can know how to make jumper/removing a component -Why jumpered or removed -what function of this jumper/removing a component i'm newbie to,so need advice from senior member |
07-06-2011, 19:20 | #2 (permalink) |
Member: 1421351 Status: Offline Sonork: 100.1605689 Thanks Meter: 143 | N70 No Network Today i receive Nokia N70 from my customer With symptom no network. No network on Dual mode or Gsm Diagnose: 1. Do searching manual in GSM mode, long time needed then show NO NETWORK from this we know that the problem came from RX (Receiver). 2. Do Self test with CYCLONEBOX, here i show you the log: Code: Selftests to proceed: 34 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Failed ST_CMT_APE_WAKEUP_TEST Passed ST_BACKUP_BATT_TEST Passed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_VIBRA_TEST Passed ST_BTEMP_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_WCDMA_TX_POWER_TEST Failed ST_CDSP_RX_IQ_LOOP_BACK_TEST Failed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Failed ST_CDSP_GSM_TX_POWER_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_BT_WAKEUP_TEST Passed ST_BT_SLEEP_CLK_TEST Selftests done, Tests total: 34, Tests passed: 30, Tests not passed: 4 Failed ST_CMT_APE_WAKEUP_TEST this is bug or what??, i don't know, Hope in new UPDATE of cyclonebox,MR.KARWOS will fix this,Or making selftest can be do or can be test separately,make easy to us Cause after vibra test all of residual test will failed (many BB5) 4. Continue... As we can see the main problem is here in red font Code: ST_CDSP_RX_PLL_PHASE_LOCK_TEST Code: Failed ST_CDSP_RX_IQ_LOOP_BACK_TEST 1. ST_CDSP_RX_PLL_PHASE_LOCK_TEST = Phase looping lock test for RECEIVER (RX PART) in this case is RX lets see on scematic which component and place of this.,in this case we have N70,this type of handset have 2 RF ic thats call VINKU (TX IC) and HINKU (RX IC). In this case i have RX PROBLEM so the suspect is (HINKU IC) (now we MUST LOOK!!! at the induced problem,before DO SOMETHING!!! cause we need think twice before do REHOT,REBALL or change the IC. a lot of risk and only 50% sucess) 2. the induced problem is ST_CDSP_RX_IQ_LOOP_BACK_TEST = looping back data, this will failed because of this part is after PLL 3. lets see on scematic which component and place of this. 4. Look at handset where is it C7524???,lets change this RESULT 1. selftest LOG Code: Selftests to proceed: 34 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Failed ST_CMT_APE_WAKEUP_TEST Passed ST_BACKUP_BATT_TEST Passed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_VIBRA_TEST Passed ST_BTEMP_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_WCDMA_TX_POWER_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Failed ST_CDSP_GSM_TX_POWER_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_BT_WAKEUP_TEST Passed ST_BT_SLEEP_CLK_TEST Selftests done, Tests total: 34, Tests passed: 32, Tests not passed: 2 PROBLEM SOLVED WITH CYCLONEBOX.... THX for the team sorry if something is missing, because I'm also still learning Just press THANKS if it helps BR |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
