Old 11-13-2008, 15:50   #1 (permalink)
Member: 453862
Thanks Meter: 53
How to know it is good and perfect pm file
Plz guys any body explain how can i know that it is a good and perfect pm file ?
Any idea?
Becuse now a days most problem in nokia mobiles is signal
but not any perfect solution
some fellows says write it good pm but how can i understand it good and can solv problem?
I have nokia 1600 it came to me with problem thet
(searchs network manually ok but no access)
i wrote a pm file after it no network covrage
again i wrote others it searched a long time but at last i stop
wrote another next time but it searched two networks out of
five
at last i wrote diffrent pm files for more than 50 times
each time diffrent result(some time no access,some timeno covrage,some time all network searched and some time one or two)
plz plz help me what to do?
How can i solv my problem
is there any case like in dct3 we rebuiled imie and signal are
ok
plz plz help
The Following 2 Users Say Thank You to Tahir Riaz For This Useful Post:
Old 11-13-2008, 19:52   #2 (permalink)
Registered User
Member: 473907
Thanks Meter: 63
sir come to my shop i will understand u totally (shahid Mobiles kotsultan)
Old 11-13-2008, 21:24   #3 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Any idea?
five
ok
plz plz help
Mate when you write 50 times a pm file why you dont try to change PA,i think its a hardware fault.
Old 11-14-2008, 05:42   #4 (permalink)
Member: 453862
Thanks Meter: 53
Read this
Before writing pm file i tried much in hardware and all things changed
like pa ,filters and other components
what you say?
Old 11-14-2008, 05:59   #5 (permalink)
Member: 102582
Thanks Meter: 72
Problem is coming from 26 Mhz. or CPU.
Old 11-14-2008, 06:29   #6 (permalink)
Member: 453862
Thanks Meter: 53
Waht is 26 mhz?
Sir would you like to tell me what is 26mhz
how to check it
Old 11-14-2008, 06:33   #7 (permalink)
Member: 893354
Sonork: ron
Smile
Any idea?
five
ok
plz plz help
its better to copy a pm file into a good unit.................
Old 11-24-2008, 21:17   #8 (permalink)
Registered User
Member: 473907
Thanks Meter: 63
sir hru? me fine wish u so by the grace of *** Almighty. Some Detail about singnal
what is signal fault? and what are its kinds?
Signal faults:
signal fault in mobile phones create problem with making connection to our mobile phone tower when we feel that the signal stregnth bars are absent in our mobile phone screen then we can say that our phone has no signal. if signals in mobile phones are absent we cant make a call because there is no connection between our network and our phone that time.
Kinds of Signal fault:
there are many kinds of singal fault but we are discussing here some most common signal faults in mobile phones.
No signal
Low signal
Signal come and then disappear
signal full or satisfactory but voice cracking
No signal:
dear students now we are going to discuss here some important causes of no signal. if you find a handset with no signal inside it you can consider these components likely to be damaged.
Antenna
Antenna pad
Antenna switch
antenna tracks
Rx filters
Rf Power Amlifier
or tracks
Rf signal processor (called hagar IC in nokia)
Some time you can experience that signal fault is due to damaged antenna, so you need to replace this antenna specially in sonyericson the antenna is sticker type and it can be easily damaged so you consider first antenna in mobile phone signal faults.
Antenna pad is often rusted with corbon so you can wash it with cleaner like CTC (corbon tatra cloride) this place is often responsible for low signal faults.\
!Antenna switch is the component which is most common in mobile phone signal faults you can locate this component on the top of the mother board it is in steel case often. purpose of this component is to switch between two or some time three type of frequency bands which are (GSM 900MHz , EGSM 1800MHz, PCS 1900MHz ) you may know that there are two types of waves used in our radio section one is TX (wich is transmitted to oythers) second is RX( wich we recieve from others)
antenna swith connects GSM Rx and GSM Tx with antenna pin when it found in GSM based network and in the contrary situation it contacts DCS Rx and DCS Tx pin with antenna pin so may both signal can be communicated.
Antenna tracks are the other reason to no signal so if the contacts between antenna and antenna switch are broken there would be no signal at all.
RX Filters are used to filter incomming radio waves so may no hormonics and other frequencies could get into signal processing only targetted frequency can be enter into the specific place, so some times our RX filters filter frequency we needed as well as other frequencies you can say that they block our targetted frequency so we can replace these filters to get it repaired. this is not in common cases but we found many faults like this in nokia 8210 no signal problem.
the basic thing about radio frequency Power Amplifire is that when we need strong radio waves to spread far around then we have to use some type of amplifire wich wil be able to amlify radio waves in a good power so our mobile phone uses PA(Rf power amplifire) it is used to communicate betweent long distances lik 15-to-20 kilometers so if our PA is damaged it can not comunicate and get response from the base stations.
If the supply of PA is disconnected it cannot work so signal faults can occure so you should check PA +supply carefully.
the main head of the radio department in mobile phone is Rf signal processor which is often used to create, measure, calibrate and manage radio waves so if there is a problem in this signal processor you can say that there will be no signal at all, in some sets you can check they cannot be turned on without radio IC( rf signal processor) like in all nokia mobile phone you cannot power on a set without radio IC except special circumstances.
i m trying hardly to solve the signal fault with wholeheartedly.in short future i will solve 100% salutation.
The Following User Says Thank You to shahid555 For This Useful Post:
Old 11-25-2008, 05:29   #9 (permalink)
Member: 453862
Thanks Meter: 53
Thanks Brother
Thanks dear Shahid
i tried your methods and now i hope signal fault is a fault that can be
solved
before that we returned many phones to customers without trying
thanks very much brother
good sharing
keep it upppppppppppp
how to know box is original or cloned COMPAQ Griffin 10 01-14-2007 12:21
how to know it? .:bono:. UFS2 + UFS3-Tornadoflasher 2 01-21-2006 05:21
How to know where is russian language in MC/MW flashes? De Moon Infineon C16X M51 & ARM7 M52 BASED 15 11-13-2004 17:15
Page generated in 0.23968 seconds with 9 queries
