01-11-2007, 11:34 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Philippines - Saudi Arabia
Member: 396326 Status: Offline Thanks Meter: 229 | ULTIMATE TIPS for Not charging Display @ LCD Problem regarding not charging causes by all components conected at BSI line, Another also components connected @ BTEMP causing also not charging display CAPACITORS, VARISTOR CHIPS, and RESISTORS. Resistor between BSI and UEM not connected causing LOCAL MODE, resistor connected between BTEMP and UEM causing not charging specially 6100,3100,3120 phone. If this problem not repair for that solution the UEM is bad... capri |
01-11-2007, 17:42 | #3 (permalink) |
Member: 396326 Status: Offline Thanks Meter: 229 | Just a reminderrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrrrrrrrrr onlyyyyyyyyyyyyyyyyyyyyy!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!! |
