08-20-2007, 19:24 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | unlock nokia 1600(SIM not VALID) every body there is a solution of unlocking 1600 type Rh64 for ufs & manual.first u need to use rh64_05.530 version to erase flash and ui settings.then need to read info there u saw the provider lock code like this #pw+413007534140066+1# #pw+853751074127216+2# #pw+819691335746756+3# #pw+192104010061765+4# #pw+757560673525126+5# #pw+936372652423732+6# #pw+754210770202170+7# Here is how to enter your code once you have it: Power off phone and REMOVE SIM Power phone back on without sim Push # Push * key 3 times (you will see p) Push * key 4 times (you will see w) Push * key 2 times (you will see a +) Enter the 15 digit code Push the * ket 2 times (you will see +) Type the lock digit (this will typically be 7) Push # That's it - The phone should display "Phone restrictions off" NOTE: If the code does not work properly the first time (and you are 100% sure you enterd it correctly) - DO NOT re-enter the same code!!!! Please post your results. We assume absolutely NO responsibility if anything goes a miss. thanks buddy. |
09-04-2007, 06:02 | #7 (permalink) |
Freak Poster Join Date: Feb 2007 Location: cavite phils.
Member: 455665 Status: Offline Thanks Meter: 36 | sopnil is xplaining how to unlock 1600 step by step, thanks for that! but that procedure is too old! its easy now; using jaf is two click only first: check 2nd: unlock |
09-04-2007, 06:30 | #8 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: http://meo786.forumotion.com/ Age: 50
Member: 465162 Status: Offline Thanks Meter: 683 | Dear brother, it is very time consuming work. please do only two click, conect and unlock Muhammad Afzal Meo Quote:
nokia 1600 sim not valid | swasti | Nokia Hardware & Hardware Repair | 9 | 12-26-2008 11:54 |
1600 sim not valid imei ok unlock with jaf,ufs,fusion still same | zargar322 | Nokia Hardware & Hardware Repair | 18 | 03-15-2008 21:39 |
Nokia 1600.. will not unlock with MT-Box, Griffin or JAF | tical | Nokia Digital Core Technology 4 ( DCT-4 ) | 11 | 11-27-2006 11:22 |
