06-20-2007, 23:44 | #2 (permalink) |
Freak Poster Join Date: Dec 2004
Member: 96236 Status: Offline Thanks Meter: 7 | Hi, check these two connector, lcd conn (X4401) & keyb conn (X4400). You can also try to use another good lcd, maybe the light problem is on the display itself. Hope this help.. wbr |
06-21-2007, 01:01 | #5 (permalink) |
Product Supporter Join Date: Jul 2006 Location: BANGLADESH Age: 39
Member: 310330 Status: Offline Sonork: 100.1577334 Thanks Meter: 1,449 | Hi mr HUM. your phone is running ?if your phone is run & only display problem then pls chk your display ic.rehot your display ic or change it. if your phone is not running with incoming & out going ,only light in display then its not lcd or lcd related problem. thank chk this- BEST OF LUCK. BR, JHON. |
The Following User Says Thank You to JHON_DREAM For This Useful Post: |
06-21-2007, 20:50 | #10 (permalink) | |
Freak Poster Join Date: Sep 2005 Location: Qatar
Member: 180173 Status: Offline Thanks Meter: 28 | Quote:
did you really read? | |
The Following User Says Thank You to esma23 For This Useful Post: |
06-21-2007, 21:00 | #11 (permalink) |
Member: 180173 Status: Offline Thanks Meter: 28 | did u try to change the LCD with new? if you have try to change... sometimes the LED is damaged.. try to check the voltage if you measured same value... you can start your phone w/out the LCD... Last edited by esma23; 06-23-2007 at 07:26. |
06-23-2007, 08:40 | #13 (permalink) |
Member: 180173 Status: Offline Thanks Meter: 28 | check here the backlight IC image but you don't need to change it as you said the keypad backlight is working... first thing change the LCD with working one! if you don't have check the test point shown on the pic... for u to know where the problem is. |
..::urgent help needed 5310 no lcd light::.. | HUM | Nokia Hardware & Hardware Repair | 5 | 07-17-2011 06:45 |
..::k300i keypad light ok but no display light::.. | HUM | Sony Ericsson Hardware Repair | 5 | 07-05-2008 15:54 |
nokia 6680 no light display and keypad | marisarauso | Nokia Hardware & Hardware Repair | 9 | 11-10-2007 14:53 |
..::k300i no display light::.. | HUM | Sony Ericsson Hardware Repair | 0 | 09-14-2007 02:51 |
6680 with no displays led and no keypads led | JeAn-cLeM | Nokia Hardware & Hardware Repair | 2 | 07-17-2006 21:42 |
