Old 03-05-2002, 01:01   #1 (permalink)
ed2k_7's Avatar
Member: 4408
Thanks Meter: 5
The use of Pony Prog before nk_calc
Eeprom Sec Checksum and Eeprom Tune Checksum CAN'T be
instanly removed by "nk_calc" as some would think, locks are
all closed and some have corrupted imei digits. This must be
repaired first and foremost by Pony Prog using EEPROM READER
for EEP SEC CHECKSUM and must be corrected using reliable
soft by EEprom repairer by Bartech or Guar. Or some have
suggested transferring a good eeprom to one CS unit for quick
repair then calculate it with nk_calc then it will result only four
locks closed but different imei data...
...You need to have a good desoldering knowledge (for some
starters) and complete and reliable MBUS & EEPROM Reader
then the soft of course...
... Tested by me on 5110 and 6110 CS unit, ever than before...
Old 03-05-2002, 08:33   #2 (permalink)
Member: 5355
Thanks Meter: 5
Cool
on 3210. i think, no need to desolder. on 51/61xx, sadly i haven't test the soic clip and pony progs. btw, eeprom by bartek only correct the chksum and imei.
what does this means?
Old 03-05-2002, 21:41   #3 (permalink)
ed2k_7's Avatar
Member: 4408
Thanks Meter: 5
These was the result of Wintesla SELF-TEST: 51/61
EEPROM SEC CHECKSUM: can be repaired by Pony and CS
repairer (3rd below)
EEPROM TUNE CHECKSUM: can be repaired by by resetting>
Software> Full Factory> set (CS removed on first blink)...
...before trying to hit it with F1 F2 and F3 in nk_calc you must
make it a point that you've the tendency of permanently
destroying your phone...
... this is an old PROCESS but still reliable and TESTED...
Old 03-05-2002, 22:58   #4 (permalink)
Member: 683
Lightbulb
USE KNOK. NO NEED TO RESOLDER. READ EEPROM FROM GOOD PHONE. THEN WRITE TO TARGET PHONE.
Old 03-05-2002, 23:43   #5 (permalink)
One
Member: 3973
And what about versions sourse and target phones? It is be the same?
Old 03-06-2002, 00:40   #6 (permalink)
Member: 3918
Thanks Meter: 15
Knok works fine EXCEPT reading eeprom and saveing it (6110)
Old 03-06-2002, 03:13   #7 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 602
Hello,
Try using NokiaSP by Bph&Co and Freestyler if you don't want to
open your phone and manually read it by Pony.
B.R.
X-Shadow
P.S.
Below is the worlds most simple EEPROM programmer for 24Cxx
with Pony Prog. No components needed, just wires and a
DB-9 Female Connector.
COM Port PIN3 -------------Connect to-----> EEPROM PIN8(VC)
COM Port PIN4+PIN8 -------Connect to-----> EEPROM PIN5(SDA)
COM Port PIN5 -------------Connect to-----> EEPROM PIN4(GND)
COM Port PIN7 -------------Connect to-----> EEPROM PIN8(SCL)
Configure Pony Prog Hardware to:
Serial
SI Prog API
or
Serial
S/I Prog I/O
Old 03-06-2002, 09:07   #8 (permalink)
ed2k_7's Avatar
Member: 4408
Thanks Meter: 5
REMLE
Nice to see you back!!!
Knox not work with my 5110, but works with the 6110 I tested...
Thanks
To all,
Simple solution: If you have a damage phone but a good eeprom
for 5110 you can transfer the good from the CS and calculate it
with nk_calc... TESTED TOO!!! (simple for those who knows to
open phones)... but for now I'll be trying some solutions...
Old 03-07-2002, 09:05   #9 (permalink)
Crazy Poster
Member: 9711
ROM3???Needs network!!!
....i was meaning to make that simple programmer but...
My 5110 has an Atmel 24C16 EEPROM chip...ROM3....
...I ve flashed my phone...changed it s EEPROM contents with NokiaSP (still have the backup tho with CS) but...what more can i do to make it find the Network??I ve tried everything else!!!!
Are ROM3 phones DOOMED??????
Old 03-09-2002, 02:30   #10 (permalink)
ed2k_7's Avatar
Member: 4408
Thanks Meter: 5
ROM 3 are not doomed! I have tried all possible way to revive
its 4-locks closed to OPEN (6110) with all the FREE available soft.
Best efective way, was to change the EEPROM itself then
repair and calculate with nk_calc...
or
the unthingkable. LOG it with BOX 105, then for someone to
calculate set files for you... TESTED ON TWO UNITS with serge's
DCT-3 Pro Flasher...
LESSON: Upgrade or Change all unit but extra-carefull with
6110/5110 with DSP ROM 3...
Old 03-09-2002, 09:49   #11 (permalink)
Crazy Poster
Member: 9711
Hmmm....my problem are not the 4 locks!!!
I ve managed to unlock those (at least with version 4.59 that my phone has)...the problem is to fix that problem with the NO Network thing!!
As for the 4 locks...i had this OLA-SP dos prog that would unlock version up to 4.62. Really old one...
...this would clear USER locks...thing is it would clear locks 2 and 3 and then with another really old sw, CyberPhreak All nokias i have locks 1 and 4 cleared too.
But...wot about the signal???
Cheers!!
P.S.:Anyone wanting these progs (work ONLY with MBUS) mail me.
What is the use of the ac power Mansoor Cyclonebox 2 05-21-2009 13:00
how to i know how the version of a u900 before flashing with unlock flashes? monsterpassword FuriousGold 1 05-01-2007 18:47
What Is The Use Of Delete Of My Post chiragp Multi-Box 3 04-02-2007 15:44
whats the use of sim cloning? inwexor Sim Cloning and Scaning 3 03-11-2003 11:03
PhoneCode after the use of Ziemens 1.22! bertola x1x to x45/x50 3 07-22-2001 11:23
Page generated in 0.19992 seconds with 9 queries
