Old 01-30-2003, 13:16   #1 (permalink)
Member: 12724
Thanks Meter: 30
VBB and VCORE path Shorted to ground
In a 3310 phone,There is a short circut on VBB and vcore,both of them are connected to ground!
Should i check all capacitors between ground and VBB,VCORE lines????
Old 01-30-2003, 13:39   #2 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,653
Check PA and Charging IC.. some time cuase short.
Best Regards,
Wahab
Old 01-30-2003, 15:19   #3 (permalink)
SE-THAILAND's Avatar
Member: 10084
Thanks Meter: 277
so CPU hot?.if CPU hot from experience i thing CPU damage
Old 01-30-2003, 17:09   #4 (permalink)
Member: 12724
Thanks Meter: 30
No CCONT HOT
there is 750 mA current follow.
No VCOBBA.I changed Cobba, Vcoba is ok now but ccont hot yet.
and 700mA current .
Old 01-30-2003, 21:23   #5 (permalink)
b0ba's Avatar
Member: 6772
Thanks Meter: 17
First: Bad soldered CCONT (short on power output lines).
Secod: CCONT itself.
Third: Many components are connected to CCONT's output voltages.May be one of those or two or more components can be
faulty.
Forth: Board.
Regards
Old 01-30-2003, 23:20   #6 (permalink)
Member: 10084
Thanks Meter: 277
Originally posted by GSMLight
No CCONT HOT
and 700mA current .
ok try this.remove ccont and clean PCB.set powersupply to 2.8v then connect to VBB if not consume your lucky.if still consume try remove N100,N400,D301,D302,N200 by step.if still not work this is last choice .........CPU............
see u on chat room or icq 177537555
goodluck
Old 02-01-2003, 07:04   #7 (permalink)
Member: 12724
Thanks Meter: 30
thanks
Old 02-06-2003, 09:38   #8 (permalink)
Member: 12724
Thanks Meter: 30
With out any BGA on board there is still short VBB to ground!!
I think one of capacitors borned.
I discarded board and changed it with new one.
Old 02-06-2003, 10:38   #9 (permalink)
mobilemafia's Avatar
Member: 7889
Thanks Meter: 7
mad is faulty
Old 02-08-2003, 11:55   #10 (permalink)
Member: 12724
Thanks Meter: 30
It is OK.Mad was the problem
Old 02-09-2003, 09:14   #11 (permalink)
Member: 10084
Thanks Meter: 277
i can solve this success but stupid in vision of engineer
Old 02-09-2003, 18:05   #12 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 950
When VBB and Vcore are shorted to GND - for sure MAD2 is problem i have from 2 days 3 pcs with same fault - only one i was repair - all others - CPU lines are damaged when try to take out processor - uff - 33xx CPU is so hard to replace...
If someone have some easiest way to **** glue under MAD2 - let me know...
Old 02-10-2003, 10:45   #13 (permalink)
Member: 12724
Thanks Meter: 30
let me know too
HUAWEI C2885 charging path short ameerali19 Various 0 12-26-2008 11:37
3120 Signal move and come after short time Talagang Nokia Hardware & Hardware Repair 6 03-29-2007 11:52
2650 not charging,the + and - is showing short circuit GOODNESS Nokia Hardware & Hardware Repair 4 06-29-2006 10:36
@@@ SOLUTION short power connector to ground @@@ zine DreamBox 0 06-05-2006 20:43
LG L340i and L342i blocks shortly after start SoulLess LG 0 05-04-2006 17:57
Page generated in 0.38599 seconds with 8 queries
