04-27-2007, 13:30 | #1 (permalink) |
Junior Member Join Date: Oct 2006
Member: 361715 Status: Offline Thanks Meter: 0 | Water damaged Nokia E61 - few problems remain... However, there are still two problems remaining. 1) The battery seems to drain overnight if I switch off the phone (haven't tested it with the phone on yet). I re-cleaned the battery contacts and connector, but it did not help. I measure ~110 ohms between the + and - terminals on the battery with the battery out. The battery does not discharge out of the phone. 2) I have been unable to use the WLAN functionality. Bluetooth works fine, and I believe BT and WLAN uses the same antenna assembly. Any suggestions on what I can try for either of these problems? All the circuits are encased in soldered RF shields, so I can't get to it - I just soaked it with alcohol. |
nokia 1202 water damage after insert sim problem | alkesh02 | Nokia Hardware & Hardware Repair | 18 | 09-05-2010 21:53 |
water damaged nokia n96 | gordmeister | Nokia Hardware & Hardware Repair | 1 | 09-08-2009 00:04 |
Water damaged Nokia E65 ... | debeliamark | Nokia Hardware & Hardware Repair | 0 | 01-07-2008 09:47 |
help needed for revived water damaged nokia 2310 | benarmand | MT-BOX | 1 | 05-28-2007 21:33 |
water damage nokia 6800 no signal | raycon_24 | Nokia Hardware & Hardware Repair | 3 | 10-16-2006 07:17 |
