01-22-2005, 16:11 | #1 (permalink) |
Freak Poster Join Date: May 2003
Member: 28849 Status: Offline Thanks Meter: 0 | water fall 6230 dead does anybody know how can i repair it? or what might have been damaged to it? THANKS!!!!!!!!!!!! |
01-23-2005, 08:46 | #2 (permalink) |
Junior Member Join Date: Jan 2005 Age: 33
Member: 109009 Status: Offline Thanks Meter: 0 | i had bought a water damaged 6230 for only $15, i took it to a repair shop where they charged me $80. The problem was that there was Corrosions by the main power supply. Try locating a PCS repair center near you |
07-19-2005, 09:04 | #3 (permalink) |
Freak Poster Join Date: May 2002 Location: Germany Age: 40
Member: 12274 Status: Offline Thanks Meter: 12 | try to clean the set with ultrasonic cleaner, if not work try reflow flash, ram, app. ram, tiku upp, helga,small dc-dc conv. near batt connector, try full flash etc. |
07-19-2005, 09:18 | #4 (permalink) |
Freak Poster Join Date: Apr 2004 Location: in the kingdom of heaven Age: 40
Member: 61541 Status: Offline Thanks Meter: 1 | I have repaired many water damaged phones.Do this: 1) Remove all parts from pcb (which can be removed without soldering) 2) Put pcb into ultrasonic cleaner 3) Clean pcb with isopropylalcohol 4) If needed use FLUX to resolder contacts 5) Clean pcb with isopropylalcohol 6) Fullflash phone For me 75% success! |
07-28-2005, 17:00 | #5 (permalink) |
Freak Poster Join Date: Dec 2002 Location: http://www.gsmservice-bg.com/ Age: 52
Member: 18788 Status: Offline Thanks Meter: 10 | 6230 water damage Hi. I also have water damaged 6230.I cleaned it and now when i try to switch it on color lines appear on the displey for a few seconds and then phone is off.Sometimes even the backlight ot the displey is working but only for a few seconds. What should i do,how to repair this phone? Give me a hint,if it's possible with picture. thanks in advantage |
09-10-2005, 17:08 | #8 (permalink) |
Member: 12274 Status: Offline Thanks Meter: 12 | yes, there are a lot of repair solutions for water damaged phones like cleaning with ultrasonic, reballing ic's, locating the most affected zone, cleaning it from oxydes wich short connections, rebuilding broken track's etc.. The most important thing...an water damaged phone presents no more warranty of correct functionality in the future... |
NOKIA 6230 dead after water demage | ebu mohammed-emin | Nokia Hardware & Hardware Repair | 3 | 11-15-2006 22:13 |
water damege 6230 keys and led,s not work | CELL SOLUTIONS | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 12-14-2005 17:45 |
water damage 6230 keys not working | CELL SOLUTIONS | Nokia Hardware & Hardware Repair | 5 | 06-12-2005 13:16 |
Help with two 3330 after water fall | Trier | Nokia Hardware & Hardware Repair | 2 | 08-23-2002 22:49 |
5110 water fall | GSM RAJ | Nokia Hardware & Hardware Repair | 0 | 07-05-2002 00:35 |
