07-16-2007, 17:29 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: Malaysia
Member: 282073 Status: Offline Thanks Meter: 13 | weird insert sim in n1600 |
07-16-2007, 19:03 | #4 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Turkey Bursa Age: 63
Member: 128481 Status: Offline Thanks Meter: 376 | Quote:
good luck | |
08-13-2007, 10:39 | #9 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Insidegsm
Member: 309772 Status: Offline Thanks Meter: 31 | i have this insert sim 1600 i tried so many solution, anybody with best solution that works 100% |
The Following User Says Thank You to maka_gsm For This Useful Post: |
08-13-2007, 11:49 | #10 (permalink) | |
No Life Poster Join Date: May 2006 Location: in the corner Age: 35
Member: 285779 Status: Offline Thanks Meter: 49 | Quote:
if your prob not solve by other batt , hope u try replace one more sim ic . @maka gsm what solution you have try ..?? as i know the good & best is replace sim ic . | |
08-13-2007, 12:17 | #11 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 520956 Status: Offline Thanks Meter: 12 | bords,why did you busted sim ic..sim ic will not easil damage as ong it is not water damage nor falling down....all you have to do is to just apply small amount of heat...or recheck the batt.connector.. |
04-10-2008, 13:41 | #13 (permalink) |
Junior Member Join Date: Mar 2008
Member: 729498 Status: Offline Thanks Meter: 0 | hi all..do all of u face this problem b4..i have a n1600 is insertsim card..i follow the way in this forum to solve it..first i change the sim card ic but not solved..than i washed the the bottom board(charging part)...but still the same not solved the matter...but i found out that when i switch on the phone with sim card in it ...the phone will blank for 4 second then show insert sim card...in my exprience ...a normal phone will juz show us insert sim card once we switch on the phone right?no need to take 4 second rite?how come ???can anybody explain this for me??any solution for it??? i check with another battery but not reatey........plz help |
10-14-2008, 15:13 | #15 (permalink) |
Junior Member Join Date: May 2008 Location: india
Member: 774018 Status: Offline Sonork: [email protected] Thanks Meter: 0 | BEST ! make a jumper 100% works |
Insert Sim In china phone | umesh garg | Infinity-Box | 10 | 12-14-2010 10:59 |
DCT4 Mobile insert sim in time to time | tarikalikhan | Nokia Hardware & Hardware Repair | 5 | 11-07-2007 08:16 |
5200 Water Damaged Contact Service In Battery.., Insert Sim In Cable | CHAPRAN | Nokia Hardware & Hardware Repair | 3 | 09-10-2007 05:49 |
insert sim in a 02 x3? can anyone help | ashvin | Infinity-Box | 1 | 09-04-2006 21:35 |
