Old 02-15-2007, 22:29   #1 (permalink)
Member: 206402
Thanks Meter: 22
Weird problem with 6680
I have a nokia 6680. It doesn't turn on at all. The battery doesn't charge also. I thought it was a battery problem at first, but I tried different batteries and none worked. I tried the same batteries on another phone and it worked fine.
The weird thing is, when I connect the phone using UFS cables to the box, I can turn it on.
Can anybody help me get this phone repaired?
Vermsky
Old 02-16-2007, 03:48   #2 (permalink)
GSM_BLUE's Avatar
Member: 356202
Thanks Meter: 46
check battery terminal..
resolder....
br
Old 02-16-2007, 23:24   #3 (permalink)
Member: 206402
Thanks Meter: 22
checked, resoldered, same problem
Old 02-17-2007, 07:00   #4 (permalink)
Member: 388374
Thanks Meter: 49
Old 02-19-2007, 18:27   #5 (permalink)
Member: 206402
Thanks Meter: 22
Power button works. When I use battery, the phone doesn't turn on. When I use service cables, the phone turns on.
Old 02-19-2007, 18:33   #6 (permalink)
Member: 45635
Thanks Meter: 20
yes , i works all times.......
Old 02-20-2007, 02:46   #7 (permalink)
Member: 206402
Thanks Meter: 22
huh? what exactly do you mean?
Old 02-20-2007, 03:47   #8 (permalink)
GSM_BLUE's Avatar
Member: 356202
Thanks Meter: 46
it means its good solution and working most of the times...
then you must try it..
br
Old 02-20-2007, 18:17   #9 (permalink)
Member: 206402
Thanks Meter: 22
I guess you didn't read my post after that solution was posted too.
Old 02-22-2007, 05:10   #10 (permalink)
GSM_BLUE's Avatar
Member: 356202
Thanks Meter: 46
have you try to jump Z4401??
br
Old 10-04-2007, 14:46   #11 (permalink)
Member: 28214
Thanks Meter: 25
The jump z4401 is 100% work!! i have try.
Old 10-04-2007, 16:58   #12 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
hi, at first you check your on of switch then not done just re hot sdram....your problem willbe solved.........if not done post me what is the result
Old 10-04-2007, 17:17   #13 (permalink)
fonesintones's Avatar
Member: 518010
Thanks Meter: 24
hello vermsky
have you checked or flashed the software?
Weird problem with dead N73 ft.servicing Nokia Base Band 5 ( BB-5 ) 5 12-09-2006 14:41
weird problem with nokia 1100.. SicilianBoy Nokia Digital Core Technology 4 ( DCT-4 ) 1 01-05-2006 00:36
Weird problem with A60.. sergo_zmeia Siemens Hardware Repair Area 5 08-10-2005 03:50
weird problem with gd55 Bomber Panasonic 2 10-22-2003 14:27
WeiRD PrObLeM WiTh 8250 ryumahon Nokia Hardware & Hardware Repair 2 11-15-2002 16:51
Page generated in 0.23087 seconds with 9 queries
