08-01-2003, 16:10 | #1 (permalink) |
Junior Member Join Date: Jul 2003 Age: 47
Member: 35277 Status: Offline Thanks Meter: 0 | what can i do with this 3310? phone has no TX and no RX (in manualy search network is result no network) 1. i flashed uploaded new eeprom update faid and reseting 2. i was rehot averything (cobba, ccont PA ...etc) 3. i changed hagar, ccont, antena swith 4. i checked with eeprom tools v4 B-Phraks and everything was checked OK. what can i do with this please? |
08-01-2003, 17:30 | #4 (permalink) | |
Freak Poster Join Date: Jul 2002 Location: MAD Age: 50
Member: 13545 Status: Offline Thanks Meter: 2 | Quote:
if u have osilloscope then check TX/IQ signal from cobba first if not ok then check supply voltage to cobba if ok the cobba faulty or brocken soldering under it ...., try reball/change ..., then go to next step ...., check 26 mhz crystal ...., deviation must be less than 100 hz if more than 100 hz then 26 mhz crystal faulty ....,( u need frequency counter) Now post the result and then i will tell u what to do ... Good Luck ------------------ MrHazeem | |
08-06-2003, 10:16 | #8 (permalink) |
Member: 35277 Status: Offline Thanks Meter: 0 | i changed crystal .. nothing than cobba .. nothing a got original cobba back and now CS. i can flash and reseting.. everything works but still CS. maybe i hot out something yes man speaker was soft. |
08-07-2003, 14:28 | #9 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Aus. melbourne Age: 45
Member: 20639 Status: Offline Thanks Meter: 233 | @ Kamilll, CS, bcos of the cobba that u put back on is faulty or the soulder ball shorted,, u diffinately need a good cobba, it might fixed both CS and reception .. good luck |
What can i do with this?? | mkwatis | Motorola P2k | 0 | 07-31-2008 08:32 |
c115 trace on! modem on! what can i do with this | octaviuz | Motorola ODM | 1 | 05-28-2006 22:45 |
======What Can I Do In This Bad Update==================== | balal_boss | Griffin | 11 | 10-01-2004 06:00 |
what can i do to my 3310 | xxph8xx | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-03-2003 19:54 |
