12-07-2009, 03:41 | #1 (permalink) |
Freak Poster Join Date: Sep 2009
Member: 1114923 Status: Offline Thanks Meter: 224 | what kinds of problems is this 1.flash ok with update verson,power ok with normal mood, but show again contect service with battery. 2.boot not ok at all but show contect service i try to rehot upp but same. i also reboll upp and insert in same place.then when i suitch on some mobile show connect service like priviously and some became totally death can anybody suggest me who has been suffering for this problems and becam success anyway at last |
12-07-2009, 05:03 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: IN FRONT OF YOU Age: 44
Member: 475440 Status: Offline Sonork: 1604067 Thanks Meter: 965 | See brother there different causes of contact service some in software and some in hardware the option in software that your sl data is corrupted so your set will gon on contact service if you flashed your set with a bad flash file than you also get contact service some time you have bad rpl file you got contact service and in hardware if you have bad uem you will got contact service if bad flash ic you got this thats why there is no one way to solve it so you need more experience and knows about hardware and software than you can solve these kind of problems Br Asghar Hussain |
The Following User Says Thank You to mobilecitycbk For This Useful Post: |
12-07-2009, 08:01 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: BANGALORE,KARNATAKA,INDIA
Member: 677987 Status: Offline Thanks Meter: 173 | my dear freind first try to serch in forum then post check here for u r prblm http://forum.gsmhosting.com/vbb/showthread.php?t=497436 |
12-07-2009, 09:47 | #4 (permalink) |
Freak Poster Join Date: Jun 2007 Location: banglore\kerala
Member: 523496 Status: Offline Sonork: ammachis Thanks Meter: 76 | dear brother it happens due to many reasons we cannot predict it it depends upon the situation some time ok in my experience IT HAPPEND DUE TO THE FOLLOWING HARDWARE REASONS. 1CONTACT SERVICE AFTER CHANGING SIM IC-it become ready after reballing the glued ic many times,two time the phone become dead permantly 2.BECAUSE OF THE BTEMP RESISTER-while replaced the resister behind the battery connecter contact service removed 3.BECAUSE OF THE CHARGING SOCKET-as it has a connection to the uems audiosection it solved contact service many times 4.BECAUSE OF UPP-many many many times I could solved these series of phones contact service by replacing or reballing upp. THERE ARE A NUMBER OF OTHER SOLUTIONS AND REASONS I SAID MY EXPERIENCE ONLY...OKAY THERE IS NO USE IF THE PROBLEM IS WITH THE UEM AND WE CHANGE UPP SO DO OTHERS! ALL THE BEST AND PLEASE SHARE YOUR COMMENTS |
Dear sir what kind of cpu is this?and how to change imei number on this type of cpu? | n2roy | SpiderMan | 4 | 01-08-2010 06:36 |
What Kind of Terms is This..? | LoveLess | Smart-Clip | 12 | 07-22-2009 13:43 |
what kind of support is this?@pinheadZ | ADD-GSM | TSMbox+ | 4 | 11-16-2006 16:57 |
what kind of card is this? | babyblue | Sim Cloning and Scaning | 1 | 10-01-2002 19:24 |
