Old 09-18-2008, 13:49   #1 (permalink)
Member: 709604
Thanks Meter: 173
white light n-72
give me the solution for n-72 white light i alredy make the jumper from diagram but the problem remain the same any other solution for this plsssssssssssss urgent
The Following User Says Thank You to krishna.cell For This Useful Post:
Old 09-18-2008, 18:07   #2 (permalink)
mobilepoint's Avatar
Member: 201343
Thanks Meter: 26
replace lcd,,,,,,,,,,,
Old 09-18-2008, 20:07   #3 (permalink)
omega-telecom's Avatar
Member: 227959
Sonork: 100.1589050
Thanks Meter: 254
hi
your n72 work fine with white lcd display or just power on and hang because it's two different problems ??????
The Following User Says Thank You to omega-telecom For This Useful Post:
Old 09-19-2008, 04:17   #4 (permalink)
Member: 350571
Thanks Meter: 920
your phone working incomming outgoing calls?
reply here.
Old 09-19-2008, 06:44   #5 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,539
u r phone only white light remove boot ic and make jumper
Old 09-19-2008, 06:52   #6 (permalink)
billal1050's Avatar
Member: 860925
Sonork: Now I'M Malaysia
Thanks Meter: 294
Same Problem Pls Help Us................................
Old 09-19-2008, 15:29   #7 (permalink)
sphameed's Avatar
Member: 641058
Sonork: 100.1589325
Thanks Meter: 140
if phone working good only display white light check display connector 2,change display ic one by one
if white light @hang its may hopeless bcz its come from OMAP pls return to the customer
SP
Old 10-05-2008, 09:32   #8 (permalink)
Member: 478946
Thanks Meter: 67
sir i have a n72 which is white display but display is ok and set is working good without display what can i do ?
Old 10-05-2008, 09:43   #9 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
check the display ic's and connector.
Old 09-20-2009, 08:52   #10 (permalink)
pallumobile's Avatar
Member: 659890
Thanks Meter: 263
I also faces the same problem. I also make the jumper suggested in the diagram. But the problem is still the same.
1662 white light kakey Nokia Hardware & Hardware Repair 10 03-30-2010 08:02
n 72 white light nilesh_patel717 Nokia Hardware & Hardware Repair 5 01-26-2010 17:51
n-72 hang on white lighte shammysaini Nokia Hardware & Hardware Repair 13 09-20-2009 08:53
n 72 white light help vaghubha_sodha Nokia Hardware & Hardware Repair 5 08-17-2009 06:12
n 72 white light sachin_udai Nokia Hardware & Hardware Repair 1 08-06-2007 13:38
Page generated in 0.24287 seconds with 9 queries
