Old 03-26-2010, 17:27   #1 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
wich hardware problem ?
ALL MEMBERS; PLS PRESENT YOU OPINION
jaf: after prosessin faild
ufs: ui settings faild
ub: Terminated with error: No available flashloader for this HW/Flash ID [000110EA].00011166.00011176.000115E0
mxkey: phone not respondimg
this one 3110c flashing time error........and many more set in many times
what you think wich hardware problem in this case error in more time?
The Following 3 Users Say Thank You to jaleelkuttikkar For This Useful Post:
Old 03-26-2010, 18:21   #2 (permalink)
mmmfaruk's Avatar
Member: 1114923
Thanks Meter: 224
thanks
it is fine qustion
any one can say this answer?
The Following User Says Thank You to mmmfaruk For This Useful Post:
Old 03-26-2010, 18:35   #3 (permalink)
k_abhi's Avatar
Member: 1019814
Thanks Meter: 653
I dont know about UB or Mxkey, but in case of JAF n UFS, U should check ur cable, phones battery connector 1st. Most times it gets solved in these two.
Post reply.
k_abhi
The Following User Says Thank You to k_abhi For This Useful Post:
Old 03-26-2010, 18:38   #4 (permalink)
Dhika's Avatar
Member: 629320
Thanks Meter: 47
i think that prob is local mode problem the phone can't set to local mode
The Following User Says Thank You to Dhika For This Useful Post:
Old 03-26-2010, 18:42   #5 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
Post reply.
k_abhi
thanks.;brother........but more time no sucsess in you opinion
some time you opinion is right!
i need powerful answer in nokia masters
Old 03-26-2010, 19:59   #6 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
mostly from low version fermware,,,also ,cable,,,after go to hardware ,,flash and upp,,,,,
if pinout of mobile is not clean , ,,,all these are the reasons,,,of this problem,,some times,,those phone who have eno files
,,need first flash with eno,,for example,,e66,,n81,,n95,,,n96,,6210s,6120s,, and many more,,,,after eno reflash with latest fermware,,,,,,this is my openion,,
The Following User Says Thank You to alkhaleejmobile For This Useful Post:
Old 03-27-2010, 06:32   #7 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
no brother;low version flashing coming this error........but after high version flash need sucsess; but same problem.......
Old 03-27-2010, 08:56   #8 (permalink)
Registered User
Member: 620883
Thanks Meter: 38
good qustion bro any one can say this answer???
The Following User Says Thank You to viaraja For This Useful Post:
Old 03-27-2010, 09:37   #9 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
rebool rap ic or flash ic
The Following User Says Thank You to d.jain For This Useful Post:
Old 03-27-2010, 09:43   #10 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
all time all model this sucsess.........?
Old 03-27-2010, 10:14   #11 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
Originally Posted by nk_gsm View Post
brother; why repeat you post link adv: 4 time repeat this post
you need new thread start! no need spaming here.........
Old 03-27-2010, 10:25   #12 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
you use anther pc and chack same time wondes carepetd
Old 03-27-2010, 11:30   #13 (permalink)
Member: 975961
Sonork: +91-9897902397
Thanks Meter: 69
use mt-box and use USB flashing
Old 03-27-2010, 12:43   #14 (permalink)
Member: 1169319
Thanks Meter: 8
brother its file problum also. maby old and also cable .
Old 03-27-2010, 13:41   #15 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
usb flashing time coming this error
Programming completed in 11.250 s
[ADL] Pooling for ADL device
[ADL] Timeout, no usb device found.
wich hardware difrrent jaleelkuttikkar Nokia Hardware & Hardware Repair 1 03-09-2010 13:29
N6600 Color Problem (is It A Hardware Problem Or Display Problem)? amitsrivastava Nokia Hardware & Hardware Repair 4 01-18-2006 18:39
Hardware Problem OR software problem... MrHazeem Nokia Hardware & Hardware Repair 2 11-08-2002 07:21
Page generated in 0.30154 seconds with 10 queries
