09-25-2002, 10:26 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: London, UK
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | @willy many people ask and even myself---about the changing of the bga like ccont , flash ram --etc- whihc are glued-- how to change them-- kindly guide a easy and safest method ---- best regards gohar |
09-25-2002, 14:17 | #2 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: @willy HI Mod, to remove CCONT with glued , i used (hakko 850) to set : AIR : 3.5 heater: 3 if use temp. meter to test it with 2 CM, it around 260 ~280 C., first heat side of CCONT, till tin come out ! then continue to heat CCONT and use knife to "VERY SLOW" to pull up CCONT ! almost all glue will stay in CCONT chip, PCB have few glue only! then make AIR to 1, heater set to 2.5, then use knife to clean glue in PCB ! then clean CCONT chip upper all tin , and you can easy remove glue as like remove a paper ! Willy Quote:
09-26-2002, 02:43 | #3 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | this way only useful if u have one side of the i c from the four side of it not filled with the epoxy but full coverd as the mad2 or flash rom in 8210 i don't think so correct me if i m wrong |
09-26-2002, 20:23 | #9 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | Yes, there is however to say an important thing, to work the component BGA has to have a good hand and above all you has to understand how much air to use and how much heat for every type of component, if you succeed in understanding this the game is done. [QUOTE]Originally posted by willy @Pandemonio100 also use squaren nozzle to heat MAD , so, it will not go over to flash rom or CCONT Willy [/QUOTE) |
09-28-2002, 17:22 | #11 (permalink) |
Member: 7062 Status: Offline Thanks Meter: 126 | willy ...... please keep some secrets please willy keep some secrets we reach to thiis level by cost us very expinsive ways .. like losing working bcp to have these secrets .. give advice not full experince as like u do .. any way u do a very very very big favour to ur freinds and this furom tooo ,.. all profissional repaires know that well that u make marvilles working here |
09-28-2002, 18:10 | #12 (permalink) |
Member: 1060 Status: Offline Thanks Meter: 10 | @raheeeeb i just share what i used to work with chips which hold by glue ! and i also know, here this forum , there are lot of proficiency mambers, even have better way ,, and me, i am just student too Willy |
10-31-2002, 10:44 | #13 (permalink) |
Junior Member Join Date: Oct 2002 Location: IND Age: 53
Member: 16982 Status: Offline Thanks Meter: 0 | Willy willy dear sir i have the problem in 3310, if turn on the phone is ok in 900MHz and 1800 MHz but after 30 sec I make a call the phone say that the bat is low and shunt down even the bat is full, can you give me soma explanation for this i realy don't know what the problem because i already change ccont but still like that regards Irawan |
11-01-2002, 03:22 | #15 (permalink) |
Member: 16982 Status: Offline Thanks Meter: 0 | Willy i check my pa is good because i use like pad and you put at the back of antena i already change the cassing and with battery connector but still had that problem irawan6880 |
