09-15-2002, 19:58 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: India Age: 48
Member: 8587 Status: Offline Thanks Meter: 4 | Willy I have a problem I have a 3330 which kept on searching for network . I did RSSI with Wintesla which showed -144 . As you suggested in the other forum I want to measure vco out to hagar 2.8v but how and where to measure it. Since I was confused I tried reflowing Hagar and Cobba, Now the handset is dead. Please guide me what can be done now? I want to repair the phone the procedural way, but I don't know how to measure the voltage, since if I put in the battery everything will be covered in a 3310/3330. Please help me friend. Thanx in advance Regards |
09-15-2002, 20:23 | #2 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | HI Abubaby ,, When you will measure VCO,,,,, you have to see hager control out to C558 , by use oscilloscope to check 2.8V with moduration ! For RSSI 144,,, most time,1: COBBA was problem ,2: Hager then 3:MCU then 4:VCO 5:line cut ,, you can try to see( by oscilloscope) that IP/QP before into COBBA is good or not . then go to ( by oscilloscope) to see R301 SENA and SCLK and R300 SDATA, this is between MCU to talk to HAGER path ! OK, now your have dead phone, then first to remove cobba, then goto check (by oscilloscope) C303 for 13Mhz , if none, then you check C559 ( by oscilloscope ) 13Mhz ok or not,, if not, Hager is problem ! PLEASE MEASURE EVERY THING BEFORE YOU REHOT ANY CHIPS Willy Last edited by willy; 09-15-2002 at 20:25. |
Have 2 smart phones = Sierra VOQ and am having software problems | coolbeanz | HTC & PDA WM( With Touchscreen) | 0 | 08-05-2006 01:09 |
i have a Problem With Nokia 3300 And One Problem Too : 7250i Phone Program... | Sky-Dancer | Nokia Multimedia | 2 | 10-27-2003 18:49 |
Willy, I have a problem. | .:*CHENNAI GSM*:. | Nokia Hardware & Hardware Repair | 3 | 11-21-2002 12:38 |
I have big problem with T250 -> do not unlock with TAU!! | Ved | Motorola Old Legacy (EMMI) | 7 | 12-27-2001 12:07 |
I Have a problem... | JammerOne | x1x to x45/x50 | 0 | 04-20-2001 16:46 |
