09-03-2002, 10:49 | #1 (permalink) |
Insane Poster Join Date: Dec 2001 Location: romania
Member: 7729 Status: Offline Thanks Meter: 0 | willy please help me with nokia repair i have a 6210 , vibrate not working but phone ringing! i have a 3310 , phone ringing but vibrate not working! any idea what can i do ? thank you! best regards Tod |
09-03-2002, 17:22 | #3 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: willy please help me with nokia repair Hello Tkerek, Let we say, your vibrate motor is working and connect is no problem ! for that your 6210 phone virbate problem , you can check at : http://forum.gsmhosting.com/vbb/show...threadid=53366 control source from MCU, and you have to check supply from battir then R444, V441, R440, L401, V440, L400 for your 3310,, you can check MCU to N400 in pin 19 , and out (pi 16) to R401 . of cause, VB must be good supply ! here you go: http://imagehost.auctionwatch.com/bi...s/N400_led.jpg Willy Quote:
09-08-2002, 09:43 | #5 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Tkerek, Use wintesla to set ring on or virbate on then use oscilloscope to measure MCU out to each componets ! Willy Quote:
09-08-2002, 22:01 | #7 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | HI Tkerek, solder a wire out for test ! If you have power supply, then you solder a 22K resistor from BSI to GND, and give 4V to V+ , then phone can work along with out battery . If you do not have power supply, then , you still can remove casing, and use an elastic band to make your pcb connect to battery ! Willy Quote:
please help me withe nokia 5800b!!? | planetgsm0 | Universalbox | 4 | 05-28-2009 09:58 |
NOKIA 7250 i - Urgent Help Needed..Please help me with this.... | rohit_model4u | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 08-25-2005 21:38 |
Willy please Help me about this thing.. | JammerOne | Nokia Hardware & Hardware Repair | 4 | 09-19-2002 20:44 |
willy please help me with nokia repair | tkerek | Nokia Hardware & Hardware Repair | 0 | 09-03-2002 10:43 |
Please Help Me With Nokia 6210 | Gazmce1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-26-2001 13:34 |
