09-15-2013, 12:50 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | Friends i try to flash with ufs hwk please check the logs and post the result where is the problem because set flash complete but ui setting failed and no local or test mode after flash complete... here is the logs CPU: GenuineIntel, Sp: 5 Platform: Windows NT 5.1 (Build 2600 Service Pack 3) Versions: Ufs2xx.dll 3.2.4, Ufs2xx.sys 2.8.14 Executive Path: D:\Program Files\Nokia\Phoenix UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007. Sn: 73003 HID: FA8528E342600049, HWK: A1.04-PRO1 Features: 00000001 Licence: True LogFile: .\_!_LOG\73003_91520133_1726_LOG.txt If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 921600 FL_ID : EC000424, Samsung K8x2815ETF 128Mb ShutDown Done Rebooting Mobile If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 921600 FL_ID : 00000000, Unknown 128Mb ShutDown Done Rebooting Mobile If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 921600 FL_ID : EC000424, Samsung K8x2815ETF 128Mb MCU FLASH BUNDLE: rm713_005.440 Flash File: hw_b1_rm713_r05.440.fls Erase Area: 0x00000000 - 0x0001FFFE, Erased: 00:01 Write Area: 0x00000000 - 0x00005FFE, Written: 00:00 Erase Area: 0x00800000 - 0x00BFFFFE, Erased: 00:33 Write Area: 0x00800000 - 0x00BEFFFE, Written: 01:22 Erase Area: 0x00C5D000 - 0x00E5FFFE, Erased: 00:15 Write Area: 0x00C5D000 - 0x00DFB6FE, Written: 00:25 PPM FLASH BUNDLE: rm713_005.44ie Flash File: hw_b1_rm713_005.44ie.fls Erase Area: 0x00100000 - 0x007FFFFE, Erased: 00:59 Write Area: 0x00100000 - 0x005AACBE, Written: 01:36 CNT FLASH BUNDLE: rm7130_nai05.44ie Flash File: hw_b1_rm7130_nai05.44ie.fls Erase Area: 0x00E60000 - 0x00F5FFFE, Erased: 00:08 Write Area: 0x00E60000 - 0x00F110BE, Written: 00:20 Flashing Done: 05:57 ShutDown Done UI Defaults Failed If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 921600 FL_ID : 00000000, Unknown 128Mb ShutDown Done Rebooting Mobile Init Local Mode Failed Init Local Mode Failed If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 460800 FL_ID : 00000000, Unknown 128Mb MCU FLASH BUNDLE: rm713_005.440 Flash File: hw_b1_rm713_r05.440.fls Erase Area: 0x00000000 - 0x0001FFFE, Erased: 00:00 Write Area: 0x00000000 - 0x00005FFE, Written: 00:00 Erase Area: 0x00800000 - 0x00BFFFFE...Erasing IFXFR_ERR_NO_RSP ER_ERR_GETSTAT: Erase Area: 0x00C5D000 - 0x00E5FFFE...Erasing IFXFR_ERR_NO_RSP ER_ERR_SETERASE: Process Failed, Repowering Mobile ShutDown Done If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 460800 FL_ID : 00000000, Unknown 128Mb MCU FLASH BUNDLE: rm713_005.440 Flash File: hw_b1_rm713_r05.440.fls Erase Area: 0x00000000 - 0x0001FFFE, Erased: 00:00 Write Area: 0x00000000 - 0x00005FFE, Written: 00:00 Erase Area: 0x00800000 - 0x00BFFFFE, Erased: 00:34 Write Area: 0x00800000 - 0x00BEFFFE, Written: 02:05 Erase Area: 0x00C5D000 - 0x00E5FFFE, Erased: 00:15 Write Area: 0x00C5D000 - 0x00DFB6FE, Written: 00:49 Warning, Checksum Mismatch: 0ACD > EFBC PPM FLASH BUNDLE: rm713_005.44ie Flash File: hw_b1_rm713_005.44ie.fls Erase Area: 0x00100000 - 0x007FFFFE, Erased: 01:26 Write Area: 0x00100000 - 0x005AACBE, Written: 02:20 CNT FLASH BUNDLE: rm7130_nai05.44ie Flash File: hw_b1_rm7130_nai05.44ie.fls Erase Area: 0x00E60000 - 0x00F5FFFE, Erased: 00:08 Write Area: 0x00E60000 - 0x00F110BE, Written: 00:20 Flashing Done: 08:09 ShutDown Done Init Normal Mode Failed, Fatal Error Init Local Mode Failed If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 460800 FL_ID : EC000424, Samsung K8x2815ETF 128Mb ShutDown Done Rebooting Mobile When rehot flash ic then this logs If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 460800 FL_ID : EC000424, Samsung K8x2815ETF 128Mb ShutDown Done Rebooting Mobile If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IFEBL_NO_RSP Rebooting Mobile If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 460800 FL_ID : EC000424, Samsung K8x2815ETF 128Mb MCU FLASH BUNDLE: rm713_005.440 Flash File: hw_b1_rm713_r05.440.fls Erase Area: 0x00000000 - 0x0001FFFE, Erased: 00:01 Write Area: 0x00000000 - 0x00005FFE, Written: 00:00 Erase Area: 0x00800000 - 0x00BFFFFE, Erased: 00:33 Write Area: 0x00800000 - 0x00BEFFFE...Writing IFXFR_ERR_NO_RSP WR_ERR_DATA: ,at: 008F2800 Erase Area: 0x00C5D000 - 0x00E5FFFE...Erasing IFXFR_ERR_NO_RSP ER_ERR_SETERASE: Process Failed, Repowering Mobile ShutDown Done Any solution ????????????? |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
