Old 08-09-2013, 13:49   #1 (permalink)
Major Boy's Avatar
Member: 1987269
Thanks Meter: 190
NOKIA X2-02 Contact Service
x2-02 contact service . Help me
flash v11.79
change display
but the problem same any one can help ?
here is my detail
MCU SW : V 11.79 15-08-12 RM-694 (c) Nokia
PPM SW : V 11.79 15-08-12 RM-694 (c) Nokia F
CNT SW : f_059J905 V 11.79 15-08-12 RM-694 (c) Nokia
Product : X2-02
Platform: Infineon
Prd.Code: 059N1T6
Bpr.Code: 059C943
Mod.Code: 0204922
Prod.Sn : 1E0D93ABI
HW Vers : 2000
RFIC Ver: Dummy RFIC version
LCD Type: TPO
BT MCM : 19e2-47026
BT Id : 3C 36 3D 03 D7 FF
CAM Prim: 06150123_008027
IMEI : 352440-05-735270-2
SL Conf : 001-01-00000000000
SL Prof : 800000000003000-B
SL Var : 00003524400573527000
SL Aux : 000B0000
HW Sig : 2E659313BAE6D5D8
Box Id : FFFFFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: GSM Test Equipment
ImageShack® - Online Photo and Video Hosting
The Following User Says Thank You to Major Boy For This Useful Post:
Old 08-09-2013, 14:41   #2 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
There is no solution for your x2-02 .if you change infinion power and flash then it will be solved your problem.
The Following User Says Thank You to mahzra azra For This Useful Post:
Old 08-10-2013, 08:15   #3 (permalink)
Major Boy's Avatar
Member: 1987269
Thanks Meter: 190
can you send detail information of infineon power ?
can i unlock x2-02 hwk ufs3 ?
Old 08-10-2013, 15:15   #4 (permalink)
Member: 1722956
Thanks Meter: 305
l
first bro, which kind of unlock you want to unlock? Write in details as user code,or country lock?
Why the way,for contect services of this mobile
You. Can done by changing power IC and infinion IC. For this process,first you would get a same modle mobile which would be water damage or should be such as which has as prolem as not possible to repair.replace both IC from eachother PCB.if your power and flash IC will be ok,then your mobile guaranteed on without any software.but you should be a perfect repairer of rebolling of IC.
Old 08-10-2013, 15:34   #5 (permalink)
Member: 1998530
Thanks Meter: 2
changing power IC and infinion IC x2-02 contact service problem solve
press thanks
The Following User Says Thank You to PHONE FATHER For This Useful Post:
Old 08-10-2013, 15:58   #6 (permalink)
Major Boy's Avatar
Member: 1987269
Thanks Meter: 190
l
mahzra azra you are my first friend in gsmforum
Old 08-12-2013, 10:16   #7 (permalink)
Member: 1722956
Thanks Meter: 305
bro,everyone who joint in this forum are my friends and my first and last motto is to provide my best help to whom who interpreted in any problem.i am happy to help others and I am glade you to like my post.
Page generated in 0.18666 seconds with 8 queries
