06-03-2001, 15:56 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Philippines
Member: 4274 Status: Offline Thanks Meter: 18 | Z500 duplexer (3210) |
The Following User Says Thank You to ambot For This Useful Post: |
06-03-2001, 21:17 | #2 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, Absolutely this is the most sensitive to the heat part of the whole RF unit. As less as possible temperature. Also important rule - don't put too much copper on siver or gold plated RF parts. Best Regards |
The Following User Says Thank You to Bph&co For This Useful Post: |
06-03-2001, 22:02 | #3 (permalink) |
Member: 4274 Status: Offline Thanks Meter: 18 | so this Z500 is the possible problem on my phone(3210) for not having a signal? Because i have tried to heat up this one and also put a little more soldering lead on its terminal... |
06-04-2001, 20:32 | #4 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, Common problem with the bad/no reception in 3210 is Cobba chip. As you know this chip contain all ADC/DAC converters needed for convert I/Q analog signals to digital and back. Bad connection of the balls under the chip will cause also breaking of audio path. I saw some new versions have a glue a side of Cobba to prevent breaking the balls. To check is that a problem - twist the board (reasonable angle !) and check for change in the RSSI value change( WinTesla tests ) Best Regards |
06-05-2001, 14:18 | #5 (permalink) |
Member: 4274 Status: Offline Thanks Meter: 18 | the cobba in this unit had a glue at all sides, as i inspected with a microscope all sides with a glue were all intact and i tried to **** again with a hot air with the use of hakko850 but the unit still the same (no signal)... by the way i have accidentally put a soldering lead on the copper pad of the Z500 because i'm trying to resolder the contacts, so, does this could affect the component function? and also sorry i don't have any idea yet with regards to wintesla... if it's okey with you, can you teach me how to use it and what are the materials do i need when i have to use the wintesla? i do have a service manual... |
lg u8120 pa and duplexer,needed for buy | GOODNESS | LG | 0 | 12-19-2006 20:24 |
Sony duplex software? | Lajos | Sony Ericsson Media, RingTones, Games | 0 | 01-12-2005 12:31 |
6100 duplex | tgsm | Nokia Hardware & Hardware Repair | 1 | 11-19-2004 11:33 |
1100 duplexer,how to test without it? | fiZ | Nokia Hardware & Hardware Repair | 1 | 11-02-2004 12:27 |
Flasher updatet with duplex MBUS for FAID calc without Dejan | jan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 21 | 02-17-2002 16:29 |
