Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Universal GSM Software
Universal GSM Software Write here for questions about Universal GSM Software. Example: USPU, twinsim, sms-soft, drivers...
Old 06-01-2017, 07:10   #1 (permalink)
hagard's Avatar
Member: 161547
Thanks Meter: 241
All Samsung Frp HiJacker by Hagard (2017)
All Samsung FRP HiJacker 2017 latest updated tool.This tool 100% working and tested.
FRP HiJacker V1.0
Features:
* Remove Samsung FRP 2017 in Download Mode (No More Combination Files and No more tricks)
* Softbrick fixer
*Phone Dialer (To bypass Google Account)
*ADB Enabler Tool
*ADB FRP Remover
How to Install :
*Download the File below.
*Make sure you have installed Network Framework 4.5.2 Download here -->https://www.microsoft.com/en-us/down....aspx?id=42642
*Double click the Frp Hijacker by Hagard V1.0 setup.exe
*Installation Password= www .gsmhagard.com (Without Space)
Download Here ----> GsmHagard
B
Hagard
The Following 74 Users Say Thank You to hagard For This Useful Post:
Old 06-01-2017, 07:29   #2 (permalink)
.::TEAM CCS::.'s Avatar
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 325
IT SEEMS A GREAT & UNIQUE TOOL, THANKS MAN, FOR SHARING!
I'll TRY & POST RESULTS,
HOPE IT WORKS FINE.
The Following 7 Users Say Thank You to .::TEAM CCS::. For This Useful Post:
Old 06-01-2017, 09:47   #3 (permalink)
swapan's Avatar
Member: 330460
Sonork: (Off Line)
Thanks Meter: 6,479
Smile All Samsung Frp HiJacker by Hagard (2017)
All Samsung FRP HiJacker by Hagard Team 2017 latest updated tool.This tool 100% working and tested.
FRP HiJacker features; Remove FRP, Softbrick Fixer, Create ADB Enable File, Phone Dialer.
Remove FRP (ADB) and Factory Reset.
This tool required Microsoft .NET Framework 4.5.2.FRP HiJacker Supported.
Instructions...!!!
How to Remove Samsung FRP?
1. Extract the "Frp Hijacker v1.0" Tool.
2. Open "FRP Hijacker" main setup file.
3. Select your Samsung Mobile device model.
4. Connect your mobile device to your PC or Laptop via USB cable in Download mode.
5. Select Remove FRP and Click on "HIJACK IT!" button.
6. FRP Remove 100% Done. Enjoy!
Frp Hijacker v1.0
Installation Password : www. gsmhagard.com
(Don't Use Space)
The Following 26 Users Say Thank You to swapan For This Useful Post:
Old 06-01-2017, 14:27   #4 (permalink)
swapan's Avatar
Member: 330460
Sonork: (Off Line)
Thanks Meter: 6,479
Smile Samsung J500f Marshmallow Frp Remove Done
> Setting to Download Mode OK
Device is now in DOWNLOAD MODE
> Connecting Device OK
Device is connected on COM32
> Detecting Device Interface OK
Device is connected to DOWNLOAD MODE
> Removing FRP OK
Device is now CLEAN STATE
> Rebooting Device OK
The Following 6 Users Say Thank You to swapan For This Useful Post:
Old 06-01-2017, 14:28   #5 (permalink)
swapan's Avatar
Member: 330460
Sonork: (Off Line)
Thanks Meter: 6,479
Smile Samsung SM-J510FN Frp Remove
> Removing FRP OK
> Rebooting Device OK
The Following 5 Users Say Thank You to swapan For This Useful Post:
Old 06-04-2017, 19:37   #6 (permalink)
ZIYAAD STRYKER's Avatar
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 704
h200h ds supported? thx
The Following 2 Users Say Thank You to ZIYAAD STRYKER For This Useful Post:
Old 06-15-2017, 08:40   #7 (permalink)
Registered User
Member: 1669709
Sonork: 1654655
Thanks Meter: 163
sorry sir but only copy past the gsm flasher tool nothing new
sooooooooooorry
The Following 2 Users Say Thank You to kifayatjan For This Useful Post:
Old 06-16-2017, 06:11   #8 (permalink)
sanuz's Avatar
Member: 2257857
Thanks Meter: 331
Wht is actual pass...? Showing wrong password when installing thank u.
The Following 2 Users Say Thank You to sanuz For This Useful Post:
Old 06-16-2017, 06:30   #9 (permalink)
Member: 2456749
Thanks Meter: 7
@sanuz remove space btw www. gsm
The Following 2 Users Say Thank You to jeremy93 For This Useful Post:
Old 06-16-2017, 17:50   #10 (permalink)
daryl007's Avatar
Member: 980307
Sonork: 100.1649165
Thanks Meter: 173
(Don't Use Space)
The Following 3 Users Say Thank You to daryl007 For This Useful Post:
Old 06-22-2017, 01:46   #11 (permalink)
Member: 2455337
This program does not work with the latest security version, tested in J5 Prime security patch April 1, 2017
The Following User Says Thank You to Irving187 For This Useful Post:
Old 06-22-2017, 01:57   #12 (permalink)
hervie's Avatar
Member: 2714943
Thanks Meter: 94
tested security patch level 2017............
The Following User Says Thank You to hervie For This Useful Post:
Old 07-07-2017, 08:40   #13 (permalink)
Member: 172212
Thanks Meter: 2
Samsung SM-J510FN/DS - Ok!
J510FNXXU2AQD2
Device is connected on COM30
> Removing FRP OK
> Rebooting Device OK
The Following 2 Users Say Thank You to Vad_n For This Useful Post:
Old 07-20-2017, 14:46   #14 (permalink)
Member: 2601587
Thanks Meter: 201
Password ok and also work fine......... thanks
The Following 4 Users Say Thank You to Sajjad_Hussain For This Useful Post:
Old 07-26-2017, 14:40   #15 (permalink)
Member: 322417
Thanks Meter: 940
Samsung J710F 6.0.1 Not Work
Log Says OK , FRP Clean , Rebooting and Nothing
So imagine when Software is not able to sent reboot command how will remove FRP ?
What About Nougat , This one was on MM.
Any Way , for me is useless tool
Thanks
The Following 6 Users Say Thank You to Formingus For This Useful Post:
Page generated in 0.23638 seconds with 9 queries
