Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Universal GSM Software
Universal GSM Software Write here for questions about Universal GSM Software. Example: USPU, twinsim, sms-soft, drivers...
Old 04-22-2018, 14:06   #1 (permalink)
Member: 2160706
Thanks Meter: 48
APK Easy Tool for Windows
Features:
- 7z Compression-level 0-9
- APK infomation with icon by aapt dump badging
- Advanced log viewer, with .txt file selection
- Allow path changes in textbox
- Apktool.jar version selections
- Background workers
- Cancel button in waiting dialog box
- Clear logs when exit
- Compile APK
- Decompile APK
- Drag and drop file support
- Enable/Disable check for updates
- Enable/Disable tips and ToolTips
- Extract APK / Zip APK
- Framework installer with option to change path
- Framework tagging
- Full environment path support
- Full options of decompile and compile
- Java heap. Default 1024m
- Logs tab
- Options to rename the apk file
- Quick help
- Remember path when closed
- Remember window position (SHIFT + Q to reset window position)
- Sign APK after compile
- Sign compiled APK (If you forgot to sign your compiled APK, you can sign it)
- Sign seletected APK (It will clone the selected APK, and sign it)
- SignAPK (signapk.jar v1.0)
- Smali/Baksmali
- Switch between apksigner.jar by Google and signapk.jar by bootstraponline
- ToolTips
- ZipAlign
and more...
Download Link : APKEasyTool
Page generated in 0.11046 seconds with 8 queries
