-   Universal GSM Software (http://forum.gsmhosting.com/vbb/f162/)
-   -   essay way to clear or Reset COM port (http://forum.gsmhosting.com/vbb/f162/essay-way-clear-reset-com-port-1365084/)
atif ikram 10-16-2011 20:47
Windows always assign a COM port no (like COM2, COM3 etc) every time you connect a USB device like modem, mobile phone or specially serial to USB convertors to system, and this no goes on increasing as every time you connect device windows reserve that port and next time it assign new number.
I recently face some issue because of this, I want to test my new thing magic m5e RFID Reader with BizTalk RFID which is connected to USB of my laptop using a serial to USB convertor, here my system assign a port no COM19, this was a big problem for me as my RFID Device Provider can only access up to COM5 ( it is in pre-beta) so i need to change COM port to less than COM5, when I tried to do that it shows me list of all 19 ports and mentioned in brackets as “in use”, so i need to free all these ports which are locked by system. I searched every where in device manager , control panel no interface is available to do this in windows, then i found a nice solution for this which allow you to free all ports but for this you need to edit registry,
here are the steps which you can use to free all post.
  1. Click start –> Run –> type regedit and click OK button.
  2. This will open a Registry editor.
  3. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\COM Name Arbiter
http://lh5.ggpht.com/_T-k8aOylzX0/SY...jpg?imgmax=800
Now right panel , you can see a key ComDB right click to that key and click modify. http://lh6.ggpht.com/_T-k8aOylzX0/SY...jpg?imgmax=800
In value Data section select all and delete reset to Zero ‘0’.
click OK
Close Registry editor and then restart your computer. all COM ports are now Free, you may need to reinstall any USB to serial convertor.
Note: It is always good to take back up before deleting any entry from Registry, to take back up for Com Name Arbiter, in left panel right click on COM Name Arbiter and say Export, save with some name and appropriate location.
sweet4hamza 10-16-2011 20:56
thanks dear its work 100%
SHOEB AHMED 10-16-2011 21:57
old but helpful......................
(\__/)
(")_(")
Posted: 08-23-2005
1188 - RESETTING YOUR COMPUTER'S COM PORT ASSIGNMENT - Software Bisque
Dadiggle 10-16-2011 23:26
Do not delete the ComDB key, just clear the value data (set it to zero)
The easiest way to change it is to go to device manager then right click properties, port settings tab advance then set it to the com port you want it on.
vondes 10-15-2019 20:39
The main dangers when buying an essay are the choice of a writer who works according to a template, writes off other people's ideas, arranges pieces of books and studies. But an article is not a composition. The other extreme is the writer, spitting out a stream of disconnected thoughts, not knowing how to structure theses and arguments. But an essay is not a stream of mindfulness ... Will I be able to find a professional who will surprise my teacher with harmonious reasoning and original thoughts here https://studymoose.com/conclusion-generator? Waiting for your comments, thank you)
Fromman 12-03-2019 18:57
Thanks for your explanations
Fromman 12-04-2019 19:02
Thank you for your instruction! I have to hand in my essay tomorrow and my computer has let me down. I have already read essay pro reviews because I thought I lost an opportunity to write this paper by myself.
Page generated in 0.19805 seconds with 5 queries
