Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
Universal GSM Software Write here for questions about Universal GSM Software. Example: USPU, twinsim, sms-soft, drivers... |
![]() | #31 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 48
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 238 ![]() | Also, whenever there is a date... it's shown in English apart from the month that is taken from a different language Cheers X4ce |
![]() | #32 (permalink) | ||
Junior Member ![]() ![]() Join Date: May 2013 Location: Master Mobile Market
Member: 1938175 Status: Offline Sonork: 100.88503 Thanks Meter: 7 | Quote:
please can you clear more this point br | ||
The Following User Says Thank You to Mastercode_Gsm For This Useful Post: |
![]() | #34 (permalink) |
Member: 1938175 Status: Offline Sonork: 100.88503 Thanks Meter: 7 | Or if you mean delay time status remaining x D : XX H : XX M : XX sec so it will not change till you select an order in list orders that mean if you press many time on the same order you will see the remaining time changed on every click else it will not auto decrement |
![]() | #35 (permalink) |
Member: 1938175 Status: Offline Sonork: 100.88503 Thanks Meter: 7 | Explanation about Repair Invoice categories Note Important : All data entry in repair invoice you can not edit them after saving job order , so you must double check all input data before saving order job . Customer Info : 1 - Name : your Customer Name info 2 - Mobile : your Customer Mobile number 8 or 10 digits without the code country 3 - Add PhBook : if checked then mobile number will add to phonebook.ini else if unchecked then No phone will appear in mobile field 4 - Smart Search : if you enter a mobile number that was already entered before to a customer then it will auto display the name of customer saved in Name field Note : if you enter a mobile number that was already saved with name in database and you enter a different name in field name then the soft will auto take the name saved in database for that number after saving order job. Reason : for prevent any spelling error or different name Mobile Info : 1 - Brand : Ex- SAMSUNG , APPLE , NOKIA , SONY , etc... 2 - Models : Every Brand have there own models Ex : I9300 , iPhone 5s , etc 3 - Edit Brand or Model Name : Disabled will activated in full Version Note : You can add new Brand or Model By pressing in list Add New Brand or Add New Model 4 - IMEI : 14 digits Customer Mobile with function to check if your entry IMEI Number is true or false . You can use any barcode reader to read Stickers IMEI and input directly in IMEI field 5 - Check Box if IMEI not available : checked when IMEI not available for Example : Dead iPhone or other reason. i will post the rest Explanation when i ll have more free time Master Mobile Market Team... |
![]() | #36 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Online Thanks Meter: 1,236 | Brother Cash/Credit Also Need To Added.....Also Price Tag Option So I Can Add Software Price To All Model Fix Rate For All Customer..Also Include Category Customer/Counter....Make Sure If You Add Price Tag Option there Must Be 2 Option Customer & Counter.... |
The Following User Says Thank You to hitech care For This Useful Post: |
![]() | #37 (permalink) | ||
Member: 1938175 Status: Offline Sonork: 100.88503 Thanks Meter: 7 | paid Amount or unpaid Amount for any order job already exist it will appear in complete form after you select complete order then to see which order paid or unpaid and the name of customer with all details it will appear in Mobile Repair report section and we will activate Mobile report later in the next week for beta tester Quote:
thank you and waiting more feed back from all who test the software Master Mobile Market Team... | ||
![]() | #40 (permalink) |
Member: 1938175 Status: Offline Sonork: 100.88503 Thanks Meter: 7 | as i believe there is no virus in my software , i submit a ticket to norton company to retest my software again. ![]() and also any one can scan my software with other antivirus are welcome thanks in advance Master Mobile Market Team... |
![]() | #41 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2403447 Status: Offline Thanks Meter: 1 | Hi, I'm Harry from Norton Support team. Sorry for the inconvenience. Please private message me the Submission number for your executable, I can check it further with our security response team and get back to you. Thanks! Harry Norton Support |
The Following User Says Thank You to Norton Support For This Useful Post: |
![]() | #42 (permalink) | |
1 - Select Type : List box have 2 options Hardware or Software that mean what you want to do in repairing mobile as hardware or software. 2 - Select Fault : what is the problem of mobile if it is hardware for example (Not charging - No Network - Change LCD - Change Touch- etc...) or if it is Software ( Flashing - Unlock - Repair IMEI - Format - Change Language - etc...) 3 - Add New Fault : if you select Type Hardware than New Fault will be added in Hardware List or if you select Type Software than New Fault will be added in Software List. Note : every time you select Fault it will auto appear in text area that mean you can select multiple faults for the same Order Job and maybe mixed for example problem hardware is Not charging and Flashing so you will see in text area : 1-Hardware : Not Charging ; 2-Software : Flashing. 4 - Clear Text : Remove selected Fault from text areause it when you select wrong fault. Mobile Status Received : 1 - Select Status : what is the status of mobile when you received that mean for example ( Power OFF - Hang on Logo - Broken Touch - Broken Cover - Missing Screws - etc...) Note : you can select multiple status for the same order job Mobile Accessory Received : i think it is clear but i will explain by default - Nothing - is checked and you can select multiple accessory that you received with the customer mobile Service center : 1 - Served by : the worker who receive the mobile from customer 2 - send to worker : the worker who will repair the mobile Note : you can change the worker later in control center , suppose the first worker fail in repairing the mobile and you want to send it to another pro or out side your mobile shop Time / Price Expected : 1 - Repair Time : you can select from list (1-2-3-etc..) and select (Hour - day - week - month) the time you expect to finish your job in repairing mobile customer 2 - Cost Expected : amount expected to tell your customer how much you expect the cost of repairing his mobile , and you can change it later in control center 3 - Multiple Currency : By default 3 currency exist ( USD - EURO - LBP ) and you can add your Local currency country Clear All Texts : it will clear all texts area in Repair invoice Save Order Job : it will save your order then take you to Control Centerpage Print Order Job: Print the invoice and it will be activate in full version Master Mobile Market Team... | |
![]() | #43 (permalink) | |
Member: 1834832 Status: Online Thanks Meter: 1,236 | Quote:
For Demo (While Tagging Rates) Nokia 2700C Flashing Customer Charge 5$ & Counter Charge 3$ (While Creating Invoice Receipt) Customer Type * Customer * Counter/Retailer When I Select Any Of Them Respective Rate According To Type Auto Came....(If i Select Customer 5$ If Counter 3$)..Hope You Understand.... This Is Just For Example ![]() ![]() ![]() Also Add job Id Invoice ID/No. If Not Added | |
![]() | #44 (permalink) |
Member: 1938175 Status: Offline Sonork: 100.88503 Thanks Meter: 7 | Reply from norton antivirus replying to my ticket about Master Mobile Market detected as threat in Norton internet security the answer is : ![]() and this is a proof that Master Mobile Market not contain any virus or malware etc... @ One_Hermit please you can test again Now back to work for all beta testers please i need your full report before 08/06/2015 for we can continue to the next step in testing next step is : activating Mobile order report and after we will activate the network mode for beta tester you can send report by email or ticket support or here waiting hear from you as fast as you can for prevent any delay in our plan thank you Master Mobile Market Team... |
![]() | #45 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2014 Location: India
Member: 2282226 Status: Offline Thanks Meter: 52 | thanks now working normally but facing some problem 1. software accept only 8 digit mobile number [not 10] 2. unable to save job without mobile number - mobile number not required for small jobs [security code / pattern lock & other which we can done in few minutes] please add option to save job without mobile number [same as imei tab] |
The Following User Says Thank You to One_Hermit For This Useful Post: |
