Universal GSM Software Write here for questions about Universal GSM Software. Example: USPU, twinsim, sms-soft, drivers... |
05-14-2019, 18:55 | #1 (permalink) |
Freak Poster Join Date: Apr 2014
Member: 2160706 Status: Offline Thanks Meter: 48 | Apk easy tool 1.55 Apk Easy Tool*is a lightweight application that enables you to manage, sign, compile and decompile the APK files for the apps you are working on. Allows you to manage the updates and fixes from one place The program comes with a clean and user-friendly interface that is unlikely to give you troubles. You can get started by selecting the desired file via the browsing function of the tool or drag and drop. The interface displays various information about the APK files, including package name, version, minimum SDK version and version code. From the main window, you can make the desired modifications as the main functions and additional options are all available in this tab. Speaking of functionality, some of the main operations you can perform via this tool, you can count compiling, decompiling, signing, extracting and installing the APK. In*case*you are working with ROMs only, then you can make further changes from the Framework tab. Moreover, if you feel you missed something, you can check all operations performed from the Log output tab. A straightforward app for managing APK files efficiently A noteworthy feature of the tool is that you can create the new code separately and overwrite the current APK with a simple drag and drop. It goes without saying that this operation can save you a lot of time and effort. In the eventuality that you provide frequent fixes and updates for your Android games or tools and want to be able to manage this processes smoother, then perhaps Apk Easy Tool could come in handy. - Softpedia Requirements: -*Windows*7*or above - .NET Framework 4.6.2 or above - Java SE/JDK for decompile, compile, and sign APK. If you don't have Java installed, you can only use*Zipalignor Install APK.*Download and install Java SE/JDK now Features: Decompile/Compile Decomile and compile APK, DEX and JAR files, with SPACE, symbols and germany, danish, swedish etc... characters support. Can cancel during operation Sign/Zipalign Signing and ZipAligning of APK/JAR files. Can cancel during operation Extract/Zip APK Extract and zip APK with 7z Compression-level 0-9. Can cancel during operation APK Infomation Show APK infomation with icon using aapt dump badging and link to Play Store Framework Install your framework and manage framework paths Log output View your logs to find errors. Set date to view your previous logs Sided log output is only available for higher resolution with 1250 width and above. Options Change options of tool, decompile, compile, sign and*zipalign. Options: Java heap, Apktool version, apksigner version, directories, java path, Windows explorer integration, remeber window position and more All options and textboxes are saved as config.xml and will load on launch Quick options on main. Drag and drop Drop APK, DEX, JAR files and Decompiled folder on buttons to perform actions. Drop outside buttons to select/open as file/folder Apktool.jar version selection Can switch to other versions of apktool.kar on options Add other apktool.jar in "Apktool" folder* Shortcuts 4 buttons to open work directories of decompiled APK, compiled APK, extracted APK and zipped APK* Jumplist shortcuts Windows explorer integration Do actions by just right-clicking on APK file and choose the following options, decomile or compile APK, DEX, and JAR files,*Zipalign*APK, Check align, Sign APK and Install APK Getting startedownload .msi or zip file,If you download .msi, open it and simply install it. If you download portable version .zip, extract to the*portable*drive*you like to.Launch APK Easy Tool, directory are automatically setSelect the APK file you want to work with or drop the APK to perform an actionDo some work and good luck* You do not need to select APK and set the directory if you do drag and drop actions. Framework are for ROM developers and System App modder only It works the same way as the command line version* Download link: Apkeasytool |
