Universal GSM Software Write here for questions about Universal GSM Software. Example: USPU, twinsim, sms-soft, drivers... |
12-10-2019, 14:04 | #1 (permalink) |
Freak Poster Join Date: Apr 2014
Member: 2160706 Status: Offline Thanks Meter: 48 | [TOOL][Windows] APK Easy Tool 1.56 / 1.57 beta-1 (29 nov. 2019) Features: Decompile/Compile Decomile and compile APK, DEX and JAR files, with SPACE, symbols and germany, danish, swedish etc... characters support. Can cancel during operation Sign/Zipalign Signing and ZipAligning of APK/JAR files. Can cancel during operation Extract/Zip APK Extract and zip APK with 7z Compression-level 0-9. Can cancel during operation APK Infomation Show APK infomation with icon using aapt dump badging and link to Play Store Framework Install your framework and manage framework paths Log output View your logs to find errors. Set date to view your previous logs Sided log output is only available for higher resolution with 1250 width and above. Options Change options of tool, decompile, compile, sign and zipalign. Options: Java heap, Apktool version, apksigner version, directories, java path, Windows explorer integration, remeber window position and more All options and textboxes are saved as config.xml and will load on launch Quick options on main. Drag and drop Drop APK, DEX, JAR files and Decompiled folder on buttons to perform actions. Drop outside buttons to select/open as file/folder Apktool.jar version selection Can switch to other versions of apktool.kar on options Add other apktool.jar in "Apktool" folder Shortcuts 4 buttons to open work directories of decompiled APK, compiled APK, extracted APK and zipped APK Jumplist shortcuts Windows explorer integration Do actions by just right-clicking on APK file and choose the following options, decomile or compile APK, DEX, and JAR files, Zipalign APK, Check align, Sign APK and Install APK. Download |
The Following 4 Users Say Thank You to ffzerob For This Useful Post: |
09-14-2020, 22:11 | #2 (permalink) |
Junior Member Join Date: Sep 2020 Location: Italy
Member: 2967731 Status: Offline Thanks Meter: 0 | If all is need is just APK decompilation, you can use online decompiler without installation. |
