Wanted Products Searching for hardware Product ... ? make your thread here. |
12-02-2003, 16:56 | #1 (permalink) |
Major Poster Join Date: Sep 2003
Member: 40376 Status: Offline Thanks Meter: 0 | I need a serial hub, not usb but serail [email protected] |
12-31-2003, 20:07 | #2 (permalink) |
Junior Member Join Date: Sep 2003 Location: DUBLIN, IRELAND
Member: 39322 Status: Offline Thanks Meter: 0 | i made one up with bits i got from maplin (in uk and irl). just takes a few components and a bit of soldering. could make one for you if you are stuck would cost about €25. |
01-03-2004, 12:00 | #4 (permalink) | |
Freak Poster Join Date: Nov 2002 Location: Z3 Macedonia Skopje Age: 49
Member: 17753 Status: Offline Thanks Meter: 0 | Re: I need a serial hub, not usb but serail Quote:
Serial protocol like RS 232 not support any hub you can only have switch Its imposible to connect all your RS 232 cables at once in a hub and to work! Also it is possible ro convert your USB port into COM (RS 232) but in that conversion you will lose some commands and some programs will not work! So the best way is universal box connected to a single Com port! | |
W900 Saying=preparing for file transfer,do not unplug...=But No USB or cable plugged | blaiseid | Sony Ericsson Hardware Repair | 10 | 04-03-2010 11:46 |
Sorry, but your serial is not assigned (c=0)! | trantam_web | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 05-23-2009 07:07 |
nokia1600 sim not valid but serial no ok | subhdra | Nokia Hardware & Hardware Repair | 18 | 04-27-2009 06:50 |
V3x Charge on USB but not on charger?! | darkosd | Motorola Hardware Repair | 6 | 05-14-2006 19:25 |
==Z500v NOT CHARGING BUT CONNECT 100% ON USB==SOLUTION???== | blaiseid | Samsung Hardware Repair | 5 | 02-27-2006 22:24 |
