Wanted Products Searching for hardware Product ... ? make your thread here. |
08-19-2009, 04:04 | #1 (permalink) |
Junior Member Join Date: Jun 2009 Location: Guangzhou
Member: 1051027 Status: Offline Sonork: 100.1584190 Thanks Meter: 1 | One powerful tool has all functions! Its perfect hardware features create a new gene One powerful tool has all functions! Its perfect hardware features create a new generation of Even Smart Even Faster Tianjiao. Preface; ECT product first generation of software tool released in 2002 and was non-intelligent, soon ECT Company found from the transmission line to tool hardware ware unable to quickly meet needs of newly-developed phone models. The users can not afford the follow-up huge upgrade cost, so the non-intelligent tool can not lead the market more than six months. The second generation of ECT software tool is Digital Mobile Integrate Maintain System, which was released in 2003. It introduced intelligent hardware and software technology, the first product to put FPGA technology into software tool and take the lead in achieving a non-change-main unit, continuous upgrades as well as leading the market for more than two years. But its disadvantage is high cost of adding transmission lines so that a large number of China-made phones need high pay caused by transmission line that is unaffordable to users. The third generation of ECT software tool is Mobile Intelligent Maintain System as well as the follow-up Intelligent Box series released in 2005, the third generation is a software maintenance tool breakthrough. Relying on its powerful all-intelligent hardware and software design, up to now, it’s still able to fully qualified for any needs of the market. More than ten thousand users, who rely on the ECT Company third generation; have made hundreds of thousands of money. So, the ECT Even Smarter Even Faster Tianjiao, what design concept does it have on earth? To tell here as following; First, it is a multi-interface device, and it has three sets of circuit structures. Three phones can be read and wrote at the same time. One tool equals three! The interface on the right is a standard HWK interface, through which you can read/write imported-phones. The interface on the left is for China-made phones read/write; it’s also the extension interface. The middle interface is tool main interface, to detect both imported and China-made phones. ECT Even Smarter Even Faster Tianjiao has these functions as following; 1. It can define phone pinouts definition with very high speed. The ECT Company puts an enormous effort to research phone detection technology, the build-in detection chip, FPGA, microcontroller, and upper machine synchronization with high-speed this time. In the process of system large calculation, no matter to detect USB or to detect RX and TX, it is so precise that to find the true phone pinouts definition accurately. This is accurate, stable and fast. 2. Due to the fast and accurate detection, therefore in the detection process, transmission line made by any manufacturers can be used. It no longer cares about the arrangement of cables, and users can only buy Tianjiao main unit, because transmission lines can be used or made by any other manufacturers, without affecting Tianjiao performance and speed, users can also made transmission line to save cost. 3. Control circuit of HWK enters the main interface. It freely adjusts the definition of control circuit, so transmission line by other manufacturers like NOKIA transmission line will be compatible. For example, MT BOX transmission lines are different from other transmission lines but in Tianjiao interface, it easily supports MT BOX transmission lines. Moreover, the pins in fixture may have different connections and resistance, but in Tianjiao interface it can be adjusted easily. 4.It can be set two USB definitions, two short-circuits, four groups of pull resistance up/down and cross-over circuit, in addition to the traditional definition of VCC and GND, it also can be set across-over diode VCCD (for Samsung series phone use) and current-limited hardware protection VCCP. VCCP is a very useful hardware function. In hardware design, it only provides maximum dozen mA current; under the circumstances of testing electrical level by users, it can protect phones to work normally and to protect the phone safely. Second, it is a multi-task platform It can read and write China-made phones and imported-phones at the same time to detect or read/write another China-made phones. It monitors and displays phone current supply progress. A single tool achievesproduction-line operation mode, after detection in the middle then read/write to the right interface, and keeping detecting or reading/writing next phone in the middle interface. Third, it is a multi-function platform. 1, it can be used as the maintenance power to check the current of phone that is in the process of being added power supply. And the built-in “ECT Hawkeye” analysis software observes the micro-changes of phone current and helps determine phone failure. The third yellow clip, in extension line, can set resistance value to solve phones those needed to add resistance then can power on successfully. 2. It can measure the capacity of battery. In our industry at present, most people have done battery sales or field production business, and batteries purchased in the market have been marked false capacity commonly. At the same time, some customers’ phone has serious power consumption, but they also blame on the issue of battery capacity. In order to solve these problems, the battery-detect design of Tianjiao is able to check battery charge capacity and discharge capacity. 3. It can detect ear-phone lines, charge lines and U-disk line. Also, it can check phone voltage signal as the use of low-frequency digital oscilloscope. Fourth, it is safe, durable and smart tool! Both in the process of detection and phone read/write, the separate-powered-CPU provides tens of thousands of rate per second, and tracks&collects current as well as voltage. If shows any abnormal power, it will instantly cut off phone power and give an alarm. This indicates abnormal state of your phone. All these thoughtful designs protect phone all-roundly. At the same time, multiple current and voltage protect-circuit of hardware and software monitoring technology protect tool better and better. More durable and humane tool will exclude possible human error to tool itself. Fifth, It is a continuous upgrade platform. The new expanded interface connects out the computer's USB signal, power control signals and digital I / O signals. Including the USB interface for flashing phones, it can be used to extend more functions from USB any other function I / O signals, to facilitate future sufficient expansion space. Sixth, it’s affordable for everyone! Due to the result of recent discussion about price in ECT forum and QQ groups, after ECT Company takes counsel with all sides, fully considers tremendous impact on every business by the financial recession, So ECT Company decides to bridge over the difficulties together with you, to give up high price strategy, and to set the full-set tool priced 2980 temporarily. Meanwhile, let steady customers, who have bought ECT software tool before, have the most profits by upgrading main unit priced around 1500-1600(within three months). Tools made by other manufacturers can also be provided upgrade priced around 2000RMB. |
The Following User Says Thank You to love-faith For This Useful Post: |
NEW POWER calculator tool for ALL Multi-box USER! | GSMtricks | Multi-Box | 22 | 04-17-2006 16:42 |
Tau, New Powerful Tool | magixian | Wanted Products | 3 | 01-07-2005 09:29 |
The Best Nokia DCT-4 Service Tool, check all features... | westerna | Main Sales Section | 0 | 06-13-2002 01:31 |
