Exchange Section User who want to exchange his solution or product(s) can post here, No Sales Threads otherwise it'll be deleted |
08-24-2006, 17:00 | #1 (permalink) |
Junior Member Join Date: Mar 2004 Location: Slovakia - Blava Age: 49
Member: 59539 Status: Offline Thanks Meter: 1 | VAG Tacho USB Single click access for VDO Seed-Key dashes! VAG Kombiinstrument / Immo box eeprom programmer...by OBD connector! Direct USB to OBD Connection! All hardware inside OBD connector! Works on any computer that has USB port! No more virtual COM Ports! This is a TRUE USB connection! Windows XP compatible software! Bosch/Motometer dashes for VW 2001-2002 years V07.04 & V07.05 & V07.08 (with scan for 2'nd pass) Audi A4,A6,A8 separate immo box 1994-1999 read PIN code,and read/write eeprom! Audi A3,A4,A6,TT, New Beetle Magnetti Marelli M73 (1998-2002 year) read PIN code / change mileage! New Beetle Magnetti Marelli M73 (2001 to 2005 year) read PIN code Almost all VDO dashes for VW/Seat/Skoda up to year 2004 read/write eeprom! Almost all VDO dashes for Audi up to year 2001 read/write eeprom! Almost all MotoMeter dashes for VW/Seat up to year 2001 read/write eeprom! Automatic functions: Change mileage, Read PIN code ! All this by using car OBD connector! Without disassembly dash or immo box from car! BR, [email protected] |
08-25-2006, 07:02 | #3 (permalink) | |
Freak Poster Join Date: Jan 2003
Member: 19429 Status: Offline Thanks Meter: 15 | @@@@@@@@@@ Quote:
@@@@@@@@@@@@@@@@@@@ Version ??? | |
08-25-2006, 09:04 | #5 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Watch out, vag com 607 can disable cloned interface, and some of them cannot be programmed again, depending on fuses configuration. BR |
Need Vag com usb hex schematics | Ionel | ECU & IMMO | 58 | 10-10-2010 20:35 |
VAG Diagnostic Tools VAG 908.1 | IPMART | ipmart WebShop | 0 | 01-27-2010 12:20 |
HEX USB CAN VAG-COM for 805.1 | IPMART | ipmart WebShop | 0 | 08-19-2009 22:20 |
Vag Tacho 2.5 damaged data | gsmpuky | ECU & IMMO | 1 | 08-19-2009 21:08 |
CLIPS... and TACHO MANIPULATION... | jacomell | Hardware Equipments for GSM | 2 | 06-08-2002 05:01 |
