Motorola Old Legacy (EMMI) CD520, CD930, L7089, М3x88 (3688, 3788, etc.), P7389, P7689,T180, T192, T250, T260,T2288, V50, V51, V2288, V3690,V3688 and all Timport, Accompli & StarTack Families. |
04-29-2006, 20:04 | #2 (permalink) |
Product Supporter Join Date: Dec 2001 Location: in my skin Age: 47
Member: 8086 Status: Offline Thanks Meter: 180 | 1. check LPT port settings. 2. PEMaster works correctly under DOS/WIN98 3. Roemmi may need external power supply. 4. Use other PEMaster version (I prefer 2.10 cracked by Android,that's 100% OK) 5. There are other Win based sw (eg. JIC motorola unlocker and WinEMMI) |
05-01-2006, 10:22 | #3 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | Can you post link to these software : 4 Use other PEMaster version (I prefer 2.10 cracked by Android,that's 100% OK) 5. There are other Win based sw (eg. JIC motorola unlocker and WinEMMI) |
05-02-2006, 13:14 | #5 (permalink) |
No Life Poster Join Date: Sep 2004 Location: www.thefonedoc.com Age: 55
Member: 84155 Status: Offline Thanks Meter: 8 | Version 2.1 and 2.2 are there http://www.id2.cz/sw_tested/pemaster220.zip |
05-16-2006, 19:24 | #6 (permalink) | |
Member: 43802 Status: Offline Thanks Meter: 36 | WinEmmi ? Quote:
My RoEmmi2 dongle is just an LPT key. do not see any space for connecting power. I have various PE master cracked, but the instructions are not very clear. --------------------------------- How to register this soft on you comp. With included soft(winddp cracker) read and save original HDD(from drive that you use for install this soft) id in warm place after that run disk.bat (included) and run the pemaster!if prog don`t work see what the machine ID it show! last part of id-static, first part -change as change HDD Id. all what you need-change last four digit in bat file for succes register the prog ! (if any digit of your machine id equal needed digit -dont change this digit in bat file: you id: 3031:9b45 needed 3606:9b45 so don`t change first digit-orig 1514-1722 changed 1514-1xxx first four digit not used in this ver) after some manipulate you find needed sequence for register you copy! for my comp: x6x6-9b45 x one of sequence 7-2,6-3,1-4,0-5,8-D,C-9 you change x at value from twin (f you need 1 put 4 or if need 4 put 1 into HDD id second 3x0x-9b45 x one of sequence 0-2,1-3,6-4,7-5,A-8,B-9 you change x at value from twin (f you need 6 put 4 or if need 4 put 6 into HDD id at some comp data may not equal in this case you need some calc.----------------------------------------------------------- is there any version that just works with only minor modification ? I am using Win98 and have change the serial and run the .bat file | |
HOW TO unlock SE v600i ??please help | xiongfuchen | SETool2 | 15 | 05-21-2013 08:10 |
how to unlock "htc g-1 anroide?on mxkey? | rashidbinu | MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker | 1 | 03-29-2010 16:08 |
how to unlock iphone 3.0 | louisgsm | iPhone 2 / iPhone 3G / iPhone 3GS | 10 | 03-29-2010 15:53 |
nec n223i how to unlock or how to enter code? | infogsm | NEC | 14 | 11-26-2005 13:53 |
