Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > Old Legacy Motorola (EMMI)
Old Legacy Motorola (EMMI) CD520, CD930, L7089, М3x88 (3688, 3788, etc.), P7389, P7689,T180, T192, T250, T260,T2288, V50, V51, V2288, V3690,V3688 and all Timport, Accompli & StarTack Families.
Old 04-08-2005, 16:07   #1 (permalink)
Member: 11273
I need your help with this Clip
please guide me (step by step please) to use this clip! Can I unlock 3688, 3690 with it and how? I treid but phone will be unlocked just when it stays connected to this clip and it will accespt any sim. when I disconnect it will ask for "Special Code" as usual. is there any way??
br
Old 04-08-2005, 17:31   #2 (permalink)
bungle_uk's Avatar
Member: 51154
Looks like an old EMMI clip. Its not the same as mine so this method might not work.
Hold down button on front and switch clip on with side button. Connect switched off phone to clip, switch phone on, lights should flash on clip (if it has any), wait 10 seconds, switch phone off.
Hope this helps, like I said mine is different design to yours so the procedure might be different.
Old 04-08-2005, 19:15   #3 (permalink)
Member: 11273
Thank you Bungle UK
I do always what you wrote and I get unlocked phone but when I disconnect it goes locke again. may be other tips or tricks?
br
Old 06-07-2005, 16:18   #4 (permalink)
Member: 11273
hi All
I have bought this clip about 6 monthes ago but I havent unlocked any phone with it. May be some one can help me? please take a look on the photo above.
br
Old 06-10-2005, 19:56   #5 (permalink)
bestman's Avatar
Member: 61294
Originally Posted by ab1009
Thank you Bungle UK
br
try check mobile phone interface before connecting with smart chips.
hardware appliaction , you can applied are as follow:-
1. heat charging area and allow to cool before any application is followed.
2. clean between ends of interface before any application.
3. sometimes , you can change charging unit .so, faults..
good luck ......\
bestman
[IMG] code is Off
MODs need your help with this phone! ATSC L.L.C Cruiser Suite 2 05-15-2009 01:54
Martech team i need your help on this freshwhite VSZ Service Tools 0 04-20-2009 10:04
V810 clip update tool and after update 716 unlock help with this clip Nasmi Vodafone Star 1 09-17-2008 19:40
i really need your help with this damn e600 ryumahon UFS2 + UFS3-Tornadoflasher 1 10-07-2005 13:02
please,need your help with OT301 looker Hardware Repair by brands 1 11-04-2001 18:36
Page generated in 0.24866 seconds with 12 queries
