Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Motorola > Old Legacy Motorola (EMMI)
Old Legacy Motorola (EMMI) CD520, CD930, L7089, М3x88 (3688, 3788, etc.), P7389, P7689,T180, T192, T250, T260,T2288, V50, V51, V2288, V3690,V3688 and all Timport, Accompli & StarTack Families.
Old 03-25-2003, 20:03   #1 (permalink)
Crazy Poster
Member: 7133
Unhappy Need help Startac C7_01_12 urgently!!!!
HI FRIENDS!!!
With the help of TAU Box (WinEMMI) I've downgraded FW from C7_01_12 to C7_01_08(wanted LP06) and got "Phone Phailed See Suplier".
Before this I've unsucessfully tried to backup full flash - SW asked "..need to reduce memory mode .. or battery low ..or cable wrong" or something like this..
Now phone is able to connect but I haven't repair *.hex.
Would be very appreciate for any help!
From back phone label:
type MC2-41I12 SE2949AW3E3
MSN:A282BL1FW4
I think it is M6088 or P6088(8088).
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookTwitter
Old 03-26-2003, 13:33   #2 (permalink)
Raklm's Avatar
Member: 5926
1.write good fdf for this version and all will be ok
or
2. use Asim soft and clone.dat and repair via sim
or
3. use an clone card and fix this problem
you have 3 options
of course first I prefer but I do not have good fdf for this version
Maybe someone will send you corect fdf
Rak|m
Old 03-26-2003, 14:24   #3 (permalink)
Crazy Poster
Member: 7133
Raklm, thanks for advice.
Maybe somebody has repair *.fdf?
I hope somebody has repair *.hex...
Old 03-26-2003, 16:27   #4 (permalink)
Raklm's Avatar
Member: 5926
you do not need .hex
you need just fdf for this version
or try with old Asim soft
Is ok
Rak|m
Old 03-26-2003, 16:46   #5 (permalink)
Member: 6196
to mobicell
Check you mail. Maybe I can help you
Vik
Old 03-27-2003, 05:28   #6 (permalink)
debeliamark's Avatar
Member: 4627
Try to put "00" for last byte in eeprom element 01
Old 03-29-2003, 17:39   #7 (permalink)
Crazy Poster
Member: 7133
have no result
Playing with downloaded and modifieded from phone *fdf.file did not get any sucess result.
I have not asim soft and cabel for this soft, I have only TAU Flash.
Please help me to solve problem...
Old 03-30-2003, 21:58   #8 (permalink)
Member: 2977
Unhappy
Hi !
That is M6088 Model (Startac) and I have the same Problem with this Phone...Its on Screen "Phone Phailed See Suplier".
I try with unlock with Emmi 2D box,with Moto clip,with test mode (205# 205xxx#),with reset...and nothing...I think its Solution only with repair Flash or with Eprom-flash programmer...
Regards
HJasko
Old 03-30-2003, 23:02   #9 (permalink)
Trier's Avatar
Member: 3035
Shi1t! No one reads what DEBELIAMARK have written??
Then you deserve the f_u_c_k_e_d phone to continue that way.
Old 03-31-2003, 07:56   #10 (permalink)
Member: 2977
Thanks for Your occur ... But I dont know what You mean with element 1 and 00 (I think its Asis SW or not?) Sory for my inexperience ... However Thank You wery much .... :-(
HJasko
Old 03-31-2003, 09:07   #11 (permalink)
Crazy Poster
Member: 7133
To Debeliamark
Please, explain to everybody your solution with eeprom.
Step by step, please.
Good Luck!
Old 03-31-2003, 12:28   #12 (permalink)
Trier's Avatar
Member: 3035
You need emmibox for that.
Old 04-01-2003, 05:52   #13 (permalink)
Member: 4627
Connect phone. Start GSMKEY. Press F12. You will see "Edit eeprom..." dialog. Choose 01 element and you will see 4 bytes. Edit last (or may be and second in some cases, but i think last is enough) and write back. Power off/on phone and if you see battery level and network sign on the screen - your phone is OK. Check with SIM now!
Old 04-05-2003, 17:14   #14 (permalink)
Crazy Poster
Member: 7133
Five stars to Debeliamark !
My phone was revived be full flashing with repaired *.hex by TAU Flash Box. If anybody needs mail me.
Unfortunately, it is possible to use solution of Debeliamark only with EMMI 2d (eeprom editing), but I am sure it is workable(and my friend tested).
Thanks to ALL for helpfull topic!
[IMG] code is Off
GSMCity - GSM Hosting - 1999-2010
Page generated in 0.09155 seconds with 8 queries
