Motorola Old Legacy (EMMI) CD520, CD930, L7089, М3x88 (3688, 3788, etc.), P7389, P7689,T180, T192, T250, T260,T2288, V50, V51, V2288, V3690,V3688 and all Timport, Accompli & StarTack Families. |
03-29-2001, 15:43 | #1 (permalink) |
Junior Member Join Date: Mar 2001 Location: italy
Member: 3663 Status: Offline Thanks Meter: 0 | help If I try to search again I doesn't find again the same values found the first time what can have happened? My Omn***l card still works correctly. I have used a smouse to 3.57 MHzes. Do you have some idea about? regards pierdo Ciao a tutti, io ho iniziato la ricerca del KI ( con sim_scan ) ed ho trovato 10 valori su 16 ( in 8 ore ), poi nelle successive 24 non ho trovato più nulla. Se provo a ripartire da capo non mi ritrova neppure i valori trovati la prima volta che cosa può essere successo? La mia scheda Omn***l funziona ancora correttamente. Ho usato uno smouse a 3.57 MHz. Avete qualche idea a tal riguardo? saluti pierdo |
need help master manole n95-8gb write screen restart | haslyn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-30-2010 10:56 |
max key team help urgent 6300 ? | sajjadahmad | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-29-2010 14:34 |
nokia masters need help.............. | ANILMPLY | Nokia Hardware & Hardware Repair | 0 | 03-29-2010 10:48 |
