RoEMMI BOX OFFLINE phone offline what is wrong? |
If you are using MOTOKEY + ROEMMI, disconnect motokey and try. /Odartei |
i don't have motokey i try with pemaster and i have phone offline with emidroid the same thing |
What is your port settings ??? |
lpt1 x378 and from bios epp i made my self roemmi. pemaster write phone offline and emmi is not registered to phone. what can i do? |
what kind of oscillator used in RoEmmi ? - Some versions uses external, some versions uses the BIC's internal oscillator. Make sure the oscillator works properly (e.g. frequency stability). |
with 74hc14 Can you send me a good schematic and tested? |
the problem is not in Xtal oscilator otherwise U'll see the "emmi is not connected"," waiting for connection". Check oter circuits as buffer and so on .. |
Check LPT mode - you need set in EPP\SPP Mode (SETUP BIOS) Best Regards, Alex Sed |
Help |
Help I need worked bin file for 24C04 for Roemmi2. Thanks |
