Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Old Legacy (EMMI)
Motorola Old Legacy (EMMI) CD520, CD930, L7089, М3x88 (3688, 3788, etc.), P7389, P7689,T180, T192, T250, T260,T2288, V50, V51, V2288, V3690,V3688 and all Timport, Accompli & StarTack Families.
Old 10-14-2002, 07:47   #1 (permalink)
florinmar's Avatar
Member: 8660
Thanks Meter: 3
RoEMMI BOX OFFLINE
phone offline
what is wrong?
Old 10-14-2002, 09:46   #2 (permalink)
Member: 4238
If you are using MOTOKEY + ROEMMI, disconnect motokey and try.
/Odartei
Old 10-15-2002, 07:41   #3 (permalink)
florinmar's Avatar
Member: 8660
Thanks Meter: 3
i don't have motokey
i try with pemaster and i have phone offline
with emidroid the same thing
Old 10-15-2002, 11:05   #4 (permalink)
Member: 14955
What is your port settings ???
Old 10-16-2002, 10:08   #5 (permalink)
florinmar's Avatar
Member: 8660
Thanks Meter: 3
lpt1 x378 and from bios epp
i made my self roemmi.
pemaster write phone offline and emmi is not registered to phone.
what can i do?
Old 10-16-2002, 11:20   #6 (permalink)
Member: 14955
what kind of oscillator used in RoEmmi ? - Some versions uses external, some versions uses the BIC's internal oscillator. Make sure the oscillator works properly (e.g. frequency stability).
Old 10-17-2002, 08:02   #7 (permalink)
florinmar's Avatar
Member: 8660
Thanks Meter: 3
with 74hc14
Can you send me a good schematic and tested?
Old 10-17-2002, 08:18   #8 (permalink)
comunicatel's Avatar
Member: 10201
the problem is not in Xtal oscilator otherwise U'll see the "emmi is not connected"," waiting for connection".
Check oter circuits as buffer and so on ..
Old 10-27-2002, 11:02   #9 (permalink)
Member: 7928
Check LPT mode - you need set in EPP\SPP Mode (SETUP BIOS)
Best Regards,
Alex Sed
Old 11-16-2002, 21:04   #10 (permalink)
Member: 17825
Help
Old 11-16-2002, 21:06   #11 (permalink)
Member: 17825
Help
I need worked bin file for 24C04 for Roemmi2.
Thanks
[IMG] code is Off
RoEMMI box -> EMMIDroid box Bobi Motorola Old Legacy (EMMI) 0 08-13-2002 10:57
need bin roemmi box for andromeda 1.7 boganice Motorola Old Legacy (EMMI) 0 07-09-2001 22:20
Motorolla roEMMI BOX PCB DOWNLOAD FOR TEST jonwillow Motorola Old Legacy (EMMI) 1 06-20-2001 09:37
RoEMMI Box kynky GSM Mobile Links 0 03-17-2001 19:37
GET YOUR OWN MOTOROLA ROEMMI BOX kynky GSM Mobile Links 0 01-12-2001 14:35
Page generated in 0.36617 seconds with 8 queries
