Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
06-13-2005, 11:32 | #1 (permalink) |
Freak Poster Join Date: May 2004 Age: 43
Member: 64591 Status: Offline Thanks Meter: 11 | a1000 how to reset the fone ?? i have a a1000 fone wich does run any programme bcoz of low memory ...but the fone doesnot alow to delete any itom.... please tell me what i can do to make the fone work again ..will i have to reset the fone ... if yes. how ?? Last edited by sergius; 06-13-2005 at 11:46. |
06-15-2005, 23:20 | #2 (permalink) |
Insane Poster Join Date: Feb 2005 Age: 48
Member: 112253 Status: Offline Thanks Meter: 0 | Do a master clear which can be found in the ontrol panel. Make sure you backup everything if you can. You can also send contacts from the menu via bluetooth, email etc. |
06-18-2005, 20:19 | #4 (permalink) |
Member: 112253 Status: Offline Thanks Meter: 0 | If you can't even delete stuff or run any programs then you in a bit of a bother. The only solution maybe is to reflash the phone yourself. Search in the forums for info about flashing the a1000. There is no simple solution to your problem however the phone has a self reformat function but this only happens if the c: becomes about 1.5mb or less free. The phone will reboot itself and take ages to reformat. So you think it's stuck in a reboot loop but it is reformating itself. So if you could recieve some files to fill up the c: via usb, infrared or bluetooth then it might just trigger the reformat function. |
how to reset the card to 100% ? | cellularman | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 09-24-2009 18:01 |
how to reset the paired evice in the nokia BT headset | jabran200 | Bluetooth-Hardware | 2 | 07-16-2004 15:01 |
mobitHow to reset the license of el to gsmforum? | Vlax | Trash | 0 | 07-30-2002 02:36 |
How to reset the EEPROM section in the flash file | kingbode | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-27-2001 09:28 |
Is there anyway to reset the user lock on GD93? | NUGSM | Panasonic | 1 | 10-03-2001 13:34 |
