Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 03-11-2006, 12:12   #1 (permalink)
Member: 30871
Thanks Meter: 3
A925 cant repair
after repair my boot loader in A925 i cant flash it ;i think a super-file needed
see pictures to help ,please
Old 03-11-2006, 16:20   #2 (permalink)
Member: 5926
Thanks Meter: 275
to flash this phone u need to put in update mode (intens blue screen)
Rak|m
Old 03-12-2006, 08:40   #3 (permalink)
Member: 30871
Thanks Meter: 3
Rak|m
can you explain method more details please
Old 03-13-2006, 23:53   #4 (permalink)
Member: 209437
a925 boot loader repair
Rak|m
please write me how to repair my a925 boot loader? i coud not get it in flash mode
a+b+on button does not go
Old 03-15-2006, 13:45   #5 (permalink)
Member: 30871
Thanks Meter: 3
Hardware Version PCB revision Factory Version Code Request file
A920 - M02 | 8487855M02 O | All | REL_30.80.xx_bootldr010154tsh.shx
A920 - M03 | 8487855M03 O | All | REL_30.80.xx_bootldr010154tsh.shx
A925 - P1 | 8488488N01 P1 | All | REL_30.80.xx_bootldr010154sny.shx
A925 - P2a | 8488488N01 P2a | All | REL_30.80.xx_bootldr010154sny.shx
A925 - P2b | 8488488N01 P2b | All | REL_30.80.xx_bootldr010154sn2.shx
A925 - N02 | 8488488N02 O | L960Q1 – L960Q4 | REL_30.80.xx_bootldr010154sn2.shx
A925 - N02 | 8488488N02 O | L960Q5 or beyond | REL_30.80.xx_bootldr010154sn3.shx
Note 1: PCB revision can be found under the battery, located just above the SIMCARD holder.
Note 2: FVC - Factory Version Code or Bar Code or read phone in force flash mode with USB cable.
[ How to ]
You have to install the same bootloader which you have on your device. How to change it?
1. Download RadioComm Software -> http://www.filemirrors.com/search.sr...mm&action=Find
2. Instll RadioComm.
3. Run and select 3G option and USB connect.
4. Go to '3G 6' fold, under 'All Versions' check 'Dual Processor' option and press 'Get'.
5. In fold 'AP Booter Version' we have on of following version:
apb_tsh
apb_sny
apb_sn2
apb_sn3
6. Now when you know which version you have, you can upgrade your device. Flash must be loaded to phone in PST 6.7 General or higher the same how typical firmware.
[ WARNING !!! ]
1. Download incorrect .shx file to Your phone may completly damage the possibility to load firmware again and operation phone!
2. You download the files to phone at Your own risk!
3. I don't give guaranty to this firmware files.
Regards payti & f@cio
[ http://payti.one.pl/forum ]
Old 03-20-2006, 10:30   #6 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 253
There is no way to repair phone with re-enumeration problem like this one.
Old 03-20-2006, 20:35   #7 (permalink)
Bloedman's Avatar
Member: 67905
Thanks Meter: 17
Have also renumartion problem.
Wanted to flash phone, but after a while phone switched off.
Since then i can enter bootloader but everytime it stops bei renumartion.
Please help.
cya
[IMG] code is Off
M7600 - Cant repair IMEI - Cant read Security data marquesphelder Z3X-Team Products 9 08-06-2010 07:14
i cant repair sec zone/eeprom repair hans salim Cruiser Suite 3 10-06-2008 21:53
a925 cant unlock i searched before writing salama10 Smart-Clip 2 03-10-2008 20:23
3650 nokia scrren fading cant repair with griffin mobilemafia Nokia Digital Core Technology 4 ( DCT-4 ) 6 07-26-2003 19:01
311 I cant repair ....i have Sanchez SW bart3 Philips 0 10-09-2002 09:55
Page generated in 0.20868 seconds with 10 queries
