Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
08-04-2003, 23:35 | #1 (permalink) |
Freak Poster Join Date: Mar 2001 Location: Slovakia
Member: 3835 Status: Offline Thanks Meter: 1 | C330 CONTACT SERVICE - passo don't work, pls help I have C330 contact service. I have read many old topic with this problem. I find many solution like (flash phone with "UNLOCK FLASH" -> then start PASSO software for code), but solutions don't work for me. I reflashed phone with special flash file, insert SIM CARD, run passo and wait for code. I was waiting long time for code, but passo did not find code. I was waiting around 1 hour, sometime waited longer. I was trying that a few times, but still without code Sometimes motoflasher323 soft after step 42 (sometimes after step 56) say ESTABLISHING CONNECTION WITH MOTOROLA PHONE. What is wrong??? How repair CONTACT SERVICE with other solution? Work PASSO soft for code REALLY? Please help me. PS: My friend send me unlock code, but phone still CONTACT SERVICE. Thanx BRINKI |
08-05-2003, 00:56 | #3 (permalink) | |
Member: 3835 Status: Offline Thanks Meter: 1 | Quote:
I was trying take out batery on 24 o'clock and put it back, but still same problem. brinki | |
08-05-2003, 07:37 | #4 (permalink) |
Registered User Join Date: Nov 2001 Location: Mosta Age: 53
Member: 7641 Status: Offline Thanks Meter: 26 | passo work 100%. Couple of hours a go I reflash and unlock 3 pcs wthout any problems. All proces under windows 98SE and victor flash and passo. Trye to read eeprom from one good and write i this with contact service. Make backup of eeprom in any case. |
08-05-2003, 11:21 | #5 (permalink) |
No Life Poster Join Date: Apr 2001 Location: AGADIR Morocco
Member: 3936 Status: Offline Thanks Meter: 237 | If the phone is CS just power up the phone then after insert sim card launch passo.when you get the code do not power off phone till it asks for subsidy write in the code and see regards |
08-05-2003, 12:59 | #8 (permalink) | |
Member: 3936 Status: Offline Thanks Meter: 237 | Quote:
is GSM related regards | |
08-05-2003, 13:26 | #9 (permalink) |
Junior Member Join Date: Aug 2002 Age: 60
Member: 14698 Status: Offline Thanks Meter: 0 | @brinki If you flashed phone with unlock flash for passo, code from motorolla dont help you. If you cant find unlock code with passo, it is one way - you must reflash phone with full repair flash, or contact with victorgsm WBR |
08-06-2003, 05:41 | #10 (permalink) | |
Thanx brinki | |
08-06-2003, 05:50 | #11 (permalink) |
Member: 3835 Status: Offline Thanks Meter: 1 | For all from this topic... I was trying run passo few times with MotorolaFlasherSoftware 9.9.9 crack. by spunlock, but program still say ESTABLISHING CONNECTION WITH MOTOROLA PHONE. Why??? I was trying run passo with cracked Victor software (MotorolaFlasherSoftware 3.2.3), but passo don't work. PS: When I get correct code, phone will work or not? brinki |
08-06-2003, 05:58 | #12 (permalink) |
Member: 3835 Status: Offline Thanks Meter: 1 | I forgot ... Have somebody full eeprom from C330? Pls send me via e-mail. [email protected] Thanx brinki |
08-06-2003, 21:27 | #14 (permalink) |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | i flashed my fone with PST cracked with this file TA02_G_06.04.1FR_gsm_flash_dev_ext_8M_reflash.shx after flash contact service any solution to repair ? |
SPV-Service software don't work now ? | JAVA Good | HTC & PDA WM( With Touchscreen) | 2 | 11-20-2006 16:16 |
t28 service cable don't work | djinky | Sony Ericsson | 4 | 09-06-2005 18:16 |
c330 contact service provider | Arty | Motorola P2k | 2 | 09-04-2003 20:58 |
C330 contact service provider | GSM Deals | Motorola P2k | 10 | 06-09-2003 14:33 |
C330 contact service provider | mulu | Motorola P2k | 3 | 01-26-2003 01:54 |
