Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 11-14-2005, 11:54   #1 (permalink)
Member: 77807
c650 problem - "insert sim"
hello.
Can anybody help me with "insert sim" problem on c650?
I want to know if it's soft or hard problem.
THX,
TC
Old 11-16-2005, 23:39   #2 (permalink)
Member: 119690
Originally Posted by tc_ct
hello.
THX,
TC
Have you tried to use different sim card? If that also fails, try cleaning the contacts on phone and sim. if it also fails, most probably the software is the problem. Try to upgrade then. But be sure you make back-up first.
Old 11-19-2005, 05:47   #3 (permalink)
silveraxe's Avatar
Member: 166746
Thanks Meter: 86
check with multimeter from ground if u get reading on 4 pins and one linked to earth.
the top middle pin is normal if no reading,
2ndly) If u opened the phone and did not place the heat shield correctly, also a problem for insert sim, check the shield or remove it if u opened the handset.
hope this helps
WBR
[IMG] code is Off
Nokia 7250 "insert sim" problem thecult Nokia Digital Core Technology 4 ( DCT-4 ) 5 08-05-2008 08:19
Please help! "INSERT SIM" & "NO SIM" & Manual for Quad Band TV Dual SIM TV C702 BenGman Chinese Models & Cloned Phones 1 07-28-2008 19:22
Z200 "Insert Sim" problem w7aee Sony Ericsson 0 01-21-2005 02:42
SL55 "insert sim" problem thecult Siemens Hardware Repair Area 4 09-07-2004 00:11
T65 "INSERT SIM" problem Svetli Hardware Repair by brands 4 10-05-2002 19:53
Page generated in 0.14751 seconds with 9 queries
