Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
03-08-2006, 12:19 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: U.K www.PhoneandIT.com
Member: 59991 Status: Offline Thanks Meter: 40 | E398 Unlock via Flash Backup 2.6 ? Want to remove Subsidy code, Can anyone tell me where I can fid USB drivers for E398 and how i can use Flashback to remove the code I installed the driver but I think it was not the right driver for E398, now my computer finds the right driver but cann't install, when it finds E398 usb driver it tries to install modem driver for device and then it says "An error occured blah blah" and don\'t install completly.. i think its problem with registery ,, how i can remove the old drivers completly from registery? MANY MANY THANKS IN ADVANCE Pakstar Last edited by pakstar; 03-08-2006 at 13:02. |
03-08-2006, 14:32 | #2 (permalink) |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | Hi mates 1 Right click on my computer then choice proprities 2 Added in environment variables DEVMGR_SHOW_NONPRESENT_DEVICES=1 3 delete all motorola related hidden drivers from the device manager 4 copy drivers to windirectory\system32\drivers 5 connect and do jobs. (You must point to the above directory) By the way visit this nice site Needed drivers For XP. Maybe the drivers link don't work then enter the site and past the link. Best regards, Aishur |
03-08-2006, 15:44 | #3 (permalink) | |
Member: 59991 Status: Offline Thanks Meter: 40 | Quote:
Many th anks | |
03-08-2006, 20:41 | #4 (permalink) |
Member: 28188 Status: Offline Thanks Meter: 579 | Hi mates, 1 If it's E398 with BL higher than 07.D0 You have to lower it to 07.D0. 2 Use flashbackup (for safety reason with unlocker) to backup the pds (You can also make a full backup 32 Mo) 3 use final or motorola_unlocker_2005 to unlock it. 4 Enjoy For E398s be careful. As you see it the same method as here Best regards, Aishur |
03-09-2006, 02:19 | #6 (permalink) | ||
Insane Poster Join Date: Mar 2005 Age: 36
Member: 127449 Status: Offline Thanks Meter: 1 | Quote:
This one works I believe... Quote:
03-09-2006, 12:52 | #7 (permalink) |
Member: 59991 Status: Offline Thanks Meter: 40 | In my case, I didn't do any backups, flex etc.. I just installed usb drivers for Original USB cable that came with phone E398, flashbackup 2.5 detected the phone, I clicked on Remove subsidy code, it removed the code. Note: it was written u can only try once to remove subsidy code if doesn't work, then other way so mine work first time ... didn't try again.. BR Pakstar |
03-09-2006, 13:00 | #8 (permalink) |
Member: 28188 Status: Offline Thanks Meter: 579 | Hi mates, I think you have a bl lower than or equal 07.d0. If you have damaged the pds your phone must be now dead. Original pds still needed and required, it is like teh zone for alcatel. I am sure for higher BL , your method don't work. By the way what BL have you. Best regards, Aishur |
03-09-2006, 22:27 | #9 (permalink) | |
BL 07.E0 SW version: R374_G_0E. 40.3CR Phone is in perfectly working order mate, don't call it dead u stupid making me worried. why don't u try this with V3 ? and check urself Best regards Pakstar | |
03-10-2006, 14:29 | #10 (permalink) | ||
Member: 28188 Status: Offline Thanks Meter: 579 | Quote:
Hi mates I wanna warn stuborn and blind unlockers to avoid your method. Before you press the "remove subsidy code" button in the fb 2.5, you must read what is written on its right side (Only one unlocking attempt is posssible. On fail, Restore your orginal PDS!). Then where is your PDS? hehehe... I don't gamble with customer's phones. This button has been removed in the flashbackup upgrade in order to work properly with PDS (Simulation). Read your PDS and restore it, you will be surprised. By the way, I think E398 are R372 Serie instead of R374 Finally, I have no needs to argue , continue like you do and you are in the "straight" path to Sunday unlockers (tinkers) place. Best regards, Aishur Last edited by Aishur; 03-10-2006 at 15:03. | ||
01-03-2007, 19:17 | #13 (permalink) |
Crazy Poster Join Date: May 2005 Age: 36
Member: 144117 Status: Offline Thanks Meter: 0 | Bootloader version has nothing to do with it, i think. Every moto that I tried - worked. In case Flashbackup doesn't remove the lock then check if you have the latest version of the program. |
10-01-2012, 10:58 | #14 (permalink) |
Junior Member Join Date: Sep 2011 Location: HK
Member: 1657600 Status: Offline Thanks Meter: 1 | HUAWEI E398 actually supports? is there anyone know the HUAWEI E398 specification actually? does it support LTE TDD networks? |
10-06-2012, 14:26 | #15 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Brazil
Member: 497775 Status: Offline Sonork: 100.1623579 Thanks Meter: 25 | Dear Friend... Read a Rules this forum... Not reply old messages... As model asked for you, as Huawei, an this model an old Motorola Phone. Regards... |
