Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
10-12-2008, 14:29 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | Help I killed a v3xx !! When I try to write back it's backup using flashbackup,it says error also rsdlite says error. I have v3xx BOOTLOADER:0302 R26117RK U 98.50.14R |
10-12-2008, 14:55 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: i live in lagos nigeria Age: 47
Member: 337762 Status: Offline Sonork: 100.1581304 Thanks Meter: 50 | hello mate with the kind of problem u have u are on your own i have had this sort of problems before and i end up buying another for replacement for the fone even when unlocking it a problem how much more ,i pray u get a way of solving your problem soon but wait a miunte where are smart-clip teams are they not seeing this trend do some thing fast we are counting on u . |
10-12-2008, 17:23 | #3 (permalink) | |
Freak Poster Join Date: Jan 2008
Member: 672861 Status: Offline Thanks Meter: 81 | Quote:
R26117RK_U_98.50.14R_LP0039_DRM0003_VSTU_207_0A0C_ JPPT_R26117IZARGBLVF_02_USIZRGBLVFPTR26117042_1FF http://www.4shared.com/file/63689408...17042_1FF.html No Lock. | |
The Following User Says Thank You to daywalker04 For This Useful Post: |
10-12-2008, 18:27 | #6 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | This is working flash file http://rapidshare.com/files/11554611...FDER2611705E_1 |
The Following User Says Thank You to jawad8305 For This Useful Post: |
10-12-2008, 20:11 | #8 (permalink) |
Member: 672861 Status: Offline Thanks Meter: 81 | R26117RK_U_98.50.14R_LP0039_DRM0003_VSTU_207_0A0C_ JPPT_R26117IZARGBLVF_02_USIZRGBLVFPTR26117042_1FF http://www.4shared.com/file/63689408...17042_1FF.html |
10-12-2008, 20:39 | #9 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | Thank you ALL BROTHERS,the problem RESOLVED !! by writing the same version R26117RK_U_98.50.14R wich (contains bootloAder 0302 (the same as original) I did it using rsdlite 4.2 (which is recommended for v3xx) well,Im lucky cause I found the file!!! |
06-24-2009, 08:18 | #14 (permalink) | |
Freak Poster Join Date: Nov 2002 Location: www.droidevelopers.com
Member: 17432 Status: Offline Thanks Meter: 125 | Quote:
btw , below is RSD stock firmware . . . i believe you wrongly wrote the filename. R263313_U_A0.02.03R2_USEMERALD2100P4PLR263313020 | |
help how to unlock V3XX | winemy | Motorola P2k | 25 | 04-18-2009 06:53 |
help me to unlocked v3xx 3G type | godwin | Smart-Clip | 1 | 02-07-2009 09:18 |
help me to unlocked v3xx 3G type | godwin | Motorola Hardware Repair | 0 | 02-06-2009 17:37 |
please helpe me to unlock v3xx whit cable tp | algerienbox | Motorola P2k | 6 | 01-03-2008 21:02 |
